Exhaust insulator hanger mod
#41
Received 3,858 Likes
Originally Posted by CGTSX07
just for everyones info, zipties work well also in addition to the stock oem hangers. I just added two to each hanger and adjusted the mufflers to where I wanted them. this also stiffens up the muffler so it will not sway back and forth as easily.
#43
boost owns
I have these hangers on my Tanabe MT exhaust and like them a lot. Only very minorly uneven hanging. I am sure that if I'd left the OEM hangers on it would be worse. The aftermarket ones are definitely stiffer/more solid.
#44
this is all I did:
All I did was push the muffler tip in the direction i wanted while pulling on the ziptie at the sametime in order to tighten it. I did this on both because I wanted both higher and centered. I also used two zipties on each just for better support. The hangers do not heat up so the zipties will not melt.
#46
nope, there is no melting whatsoever. yesterday would've been a good test since I drove 2 hrs straight two ways and there are no issues with melting.
DerrickW
11-15-2015 05:52 PM
InFaMouSLink
10-27-2015 06:52 PM
joflewbyu2
10-08-2015 11:16 AM
