Exhaust...
Received 3,858 Likes
wow those are now my second favorite dual exhaust tips. I like how the tips atleast appear to be really thick with the angle cut towards the inside. Cant wait to see some rear shots and also hear a soundclip of it.
Originally Posted by Yui
Very very nice. What's your favorite CCC? Looking forward to rear photos and sound clips =)
Here is a rear shot. I'll take more plus sound clips when I get a chance. The Tanabe MT pipe design before the mufflers are basically the same as the SMH. The MT is slightly quieter than the SMH during WOT and under load condition in low speed like going up a hill. Other than that, it's as quiet as the SMH during idle and cruising under steady speed. The pipe ID is ever so slightly smaller than the SMH when measured with a digital caliper. This applies to all pipe pieces and muffler inlet. The initial fitment of the muffler hanging postion was off. The left side was lower than the right, but I corrected it with this method. The exhaust tips fit really well in the under spoiler opening, but the SMH tips seem more aggressive.
MT
SMH
MT
SMH
Originally Posted by CGTSX2004
Ooh...I like the fitment and look for the MT tips. How much did you pay for it and from where did you buy it?
And THIS THREAD IS WORTHLESS WITHOUT A SOUND CLIP!!!!
Just dial 1911
1 Post
Originally Posted by TSX559
Damn. You beat me to it. I was going to ask for the price. Someone always ask for the price.
Originally Posted by joerockt
Excellerate, one of our forum vendors, is selling it for $900 shipped if I recall.
ABP TSX
Originally Posted by Knox
Those MT tips are nice. Where'd you get them?
Those tips are part of the exhaust he purchased and installed. The do not come off to install on something else for instance.
http://www.tanabe-usa.com/exhausts/medaliontouring.asp
Drives With Hands
The flare right as the tips come out of the muffler looks bad. That said, I love the chamfered tip ID, and the flare seems like it isn't visible from normal viewing positions anyway.
In fact, I'm thinking about selling my Fujitsubo since its in-cabin noise is a bit more than I'd like it to be.
I think you should take a video of your next dyno pull like I did.
Drives With Hands
Ah, see, my dyno shop uses two guys so I get to roll around back and film the exhaust note (while dodging the debris flung at me by the spinning tires).
Originally Posted by vwong
......as well as the Mugen header/cat kit.
Here it is... It's a 58 Meg file. I figure you guy wouldn't mind since you all have high speed connection.
However, make sure to right click and save target as.... Then play on your computer.
The camera is positioned 2 feet off the ground, 4 feet away from the exhaust. Here is the sequence...
start engine, idle, -> 2000 rpm & hold, -> 3000 rpm & hold, then back to idle.
Btw, I also positioned the exhaust tips slightly higher to fill the opening better.
by the way though i think your key is still in the ignition.
Just listened to it. It definitely sounds fairly quiet. JTso, how would you rate it compared to the stock exhaust in terms of loudness, assuming the stock exhaust is a 5 on a 1 to 10 scale?
