Euro R grill
Originally Posted by minkl81
usually euroR grilles have gaps on usdm bumpers and yours seems to be wider than average. did you try fitting them correctly?
Of course I have tried to install it correctly, but when I have the grill where it should be all the mounting holes on the grill are about a half a hole or more off from the ones on the bumper.
I understand there was a small difference, but I didn't think that it was this bad.
I checked the color matched trim piece part number and it matches the part number for cl-7.
71122-SEA-901ZD.
I know the color isn't right, but it was painted to match.
71122-SEA-901ZD.
its not going to fit perfectly. the holes arent going to line up too well. i just used zip ties for mine. but the bottom all you need is to slide it into the clips on the bumper.
are you suppose to to snap the center point down.. im having the same problem and i tried using zipties but i still have the gap.. any help would be greatly appreciated.
You have to push down on the center "V" until it snaps into place. It will come out looking like the OP's car.
I then just enlarged the holes slightly for the upper mounts then used zip-ties for behind the EuroR grill.
Good luck!
CL9 ABP
You might want to try taking the grill out and possibly take off part of the bumper to get those clips under the grill in firmly.
Its still will be a gap but it be better than what your showing
quanaman
01-09-2023 07:33 PM
