Custom exhaust A-pipe
I have completed the custom high flow cat and the engine seems to breath a little better. However, since the cat is 2.25" in/out and most aftermarket exhaust systems come in 2.25", I decided to modify the header A-pipe to match. The pipe is not completed yet but I thought I'd share the progress.
Here are some pics of the un-finished project.
A-pipe comparison: The header A-pipe is cut at the 2 to 1 collector. Note the size of the original DC pipe.
Flex pipe compare: The new flex pipe has an additional inner mesh lining to reduce hissing sound. Note the difference in pipe dia, and the 2 in 1 merge collector.
Merge collector:
Flange gasket: Since the pipe dia is larger, the original O-ring seal can't be used. I had to make the flange gasket with Mr.Gasket material. Note the two center circles. The smaller one is the original size, and the larger one is the new pipe size. The gasket has a metal inner layer for durability.
Merge collector:
kenstyle on 20's
damn i guess imma have to lock into all of your post now to learn what helps and dont. You are like acurazines own dyno chart man .you need to go ahead and spray it so i can see what will work the best for out cars , david
Originally Posted by kangjin
any thought of making your own race (long runner / no cat) header? all roads lead to it....
keep up the great work!
Originally Posted by Dan Martin
Looks cool. I assume you've checked this, but are there any clearance issues going with the larger flex pipe?
Originally Posted by iamhomin
That looks good. Anyways, sorry to be offtopic, but what are those wheels on your car? They don't look stock to me.
Rep'n Taxbrain.com
Wow....looks great Jtso!
Props to you man, for always coming up new ideas for mods, going out and doing them, and then posting dynos for all of us
Can't wait to see your next dyno!
Drives With Hands
How are you going to remove the ceramic coating before welding the new A-pipe to the collector?
I'm also curious as to where you got the larger flex pipe and such. I'm assuming you're going to provide further detail when this is complete, which I can resolve to wait for, but just so you know I'm curious to know about the specifics if possible.
Originally Posted by drkangel348
I see you're putting those headers you got from me to good use, nice work.
I'm looking forward to the dyno numbers.
Originally Posted by kurt_bradley
You can send it to me.
I got the flex pipe from Performance Curve. They also sell on ebay but you pay more for shipping. The pipe I got is this one in 2.25" x 6" . The flex pipe itself is 6" plus 2" extension on each side = 10" OAL. I don't think you want to go larger than 2.25" ID for NA application.
The inside of the flex pipe with the inner mesh is 2.25" ID. However, the extension inlet/outlet ID is expanded to slightly over 2.5". But the pipe that I used for collector is 2.5" OD with a 2.25" ID (thick exhaust pipe). Therefore, the entire flow path remains 2.25" and the pipe slips right on to the extension.
I also found another place that carries the similar stainless quality flex pipes but with even more options. http://www.epiflex.com/epi_flex.html
They can put together any combination of length and size of flex pipe you want. I got a quote for $50 in custom length with flex pipe. Call the listed number and speak to Rich.
If the custom A-pipe actually provides gain, then I might consider coating the header assembly. This is the same place where I coated my intake manifold. But I'd probably coat the header with a different coating.
http://www.performancecoatings.com/benefitdata.htm
Updates...
Just an update on the custom A-pipe. All the pieces are welded together and it seems to work fine. The flex section is a much better design than the DC flex pipe with an additional stainless mesh inside layer. The outlet dia. is also larger to mate with a larger CAT if necessary. I'm thinking the larger merge section and outlet might be good for FI setup.
joflewbyu2
10-08-2015 11:16 AM
09-25-2015 06:14 PM
