Comptech strut bar ordered!
Old Mar 10, 2004 | 11:57 PM
JTso's Avatar
I just ordered the Comptech strut bar, so another item off the to-do list.
Koni, you are next!
Old Mar 11, 2004 | 12:58 AM
kaikai114's Avatar
Got Milk???
keep up the good work JTso, and update us on how it goes.
Kevin
Old Mar 11, 2004 | 01:20 AM
accsuperstar's Avatar
dang baller mod
how much and where did you order from?
Old Mar 11, 2004 | 07:39 AM
JTso's Avatar
I ordered it from autocarparts for $289.97 + $15 shipping.
Old Mar 11, 2004 | 08:46 AM
Dan Martin's Avatar
Photography Nerd
Hey JTso, that autocarparts place has pretty good prices and they ship to Canada. Keep us posted on your experience buying from them because I might want to pick up a couple things....
Old Mar 11, 2004 | 08:59 AM
dom's Avatar
dom
Dan for us Canadians I think its still cheaper satying in Country. Unless your driving down for some reason.
try www.performanceimprovements.com
Acura Woodbine also carries and installs the full line of comptech parts.
Dan where did you buy your car?
Old Mar 11, 2004 | 09:25 AM
Dan Martin's Avatar
Photography Nerd
Thanks Domn, I always try to shop local just to save on shipping and duty charges. I'll try Performance Improvements sometime.
My car came from Erin Mills Acura. I know the manager of the body shop there. The whole experience was a good one. Pricing was in line with all the other quotes I got and the bonus was this dealer is like 5 mins from my house.
Old Mar 11, 2004 | 10:42 AM
tuan209's Avatar
these bars make that much of a difference? im somewhat skeptical...hehehe
Old Mar 11, 2004 | 11:37 AM
Dan Martin's Avatar
Photography Nerd
tuan209, I think the bar is mostly cosmetic but it should reduce body flex a little more than stock.
Old Mar 11, 2004 | 04:28 PM
Delmiroc's Avatar
You just ordered through the best store online IMO.
let me know how you like it ? do you currently have comptech sway bar if you don't you needed to get that first ( FOR SURE )
I might consider getting the strut bar ... depends on your review after you get it installed
Old Mar 12, 2004 | 01:10 AM
xizor's Avatar
Bye TSX, hello domestic?
I'm thinking about the neuspeed tie bar still, but I'm a little worried that adding rigidity in the front will throw off the oversteer/neutral balance that the rear sway bar supposedly adds.
Old Mar 12, 2004 | 07:35 AM
JTso's Avatar
The Neuspeed bar should work fine with the stock strut bar to strengthen the front. I wouldn't worry about the strengthen frame structure affecting handling characteristic because the tuning of suspension should base on a strong frame. You should use other components for fine tuning such as adjustable struts/shocks, spring rate, sway bar size, alignment, tires and air pressure instead.
The Neuspeed bar is much cheaper and you can get it off ebay for around $100. I like the Comptech bar for its look.
Old Mar 12, 2004 | 07:56 AM
Dan Martin's Avatar
Photography Nerd
Exactly JTso.
It's very hard to tune a suspension correctly when everything that the suspension is bolted to is flexing. Chassis rigidity is key.
Old Mar 12, 2004 | 11:47 AM
xizor's Avatar
ordered the CompTech rear sway last night, now do I go for the Neuspeed tie bar...
Old Mar 13, 2004 | 01:42 AM
JTso's Avatar
Just checked UPS tracking and the Comptech bar will arrive Monday! Damn! AutoCarparts is fast! I will definitely buy from them again. I also notice the shipping weight is 4.8 lbs comparing to the Neuspeed bar at 8.0 lbs.
Old Mar 13, 2004 | 09:49 AM
Delmiroc's Avatar
I told YA!!!
Old Mar 20, 2004 | 06:27 PM
JTso's Avatar
Comptech strut bar installed!
Okay, I finally had a chance to install the strut bar after being out of town for a week. My first impression was like damn! this thing is light, weights in about 3.25 lbs including all the mounting hardware. The stock bar is 4.0 lbs (not bad at all). Removing the stock bar was relatively easy. The hardest part was to snake it out from under the wiring harness and AC lines and clearing the mounting bolts. By no means difficult, I was being careful so took a few minutes by myself. It would be a lot easier if another person help holding one end during the removal.
After the installation, I took the car out for a spin and it felt firm and balanced. I did a few quick U-turns and it's pretty flat through out the turns. Keep in mind I also have the Comptech rear sway bar and Yoko ES100 tires so the handling was pretty good already. It basically has the same mounting design as the stock bar but has extra mounting surface coverage on the strut tower via three mounting points instead of the stock bar with two mounting points. Honestly, I think the Neuspeed bar install on top of the stock bar will provide more support than any single bar alone. The Comptech bar is good for looks.
One thing I really like about the Comptech bar is the provisioning of all stock bracket mounting points. I have never seen any aftermarket strut bars have such detail in design. The bar installs like it came from the factory. I'll let the pictures do the talking. Enjoy.
Old Mar 20, 2004 | 06:39 PM
damn what a pimp mod
Old Mar 20, 2004 | 07:05 PM
Delmiroc's Avatar
Damm bro your car keeps getting better and better ... nice
how much did you pay?
Old Mar 20, 2004 | 07:15 PM
xizor's Avatar
you know your next mod needs to be a Neuspeed Tie bar over the CompTech strut bar!
Old Mar 20, 2004 | 11:15 PM
JTso's Avatar
It was $304.97 shipped.
Old Mar 21, 2004 | 07:37 PM
leo leo's Avatar
Looking really good! Does it have 4 mounting points like one for the Accord/TL or is it just two like the neuspeed? Thanks!
Old Mar 21, 2004 | 07:51 PM
Dan Martin's Avatar
Photography Nerd
Do you actually drive that car? The engine looks like it just rolled of the assembly line!
Looking good
Jul 16, 2017 07:33 AM
lanechanger
Oct 13, 2015 10:56 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
