Can we use this ?
JDM
無限 本田 CL9
if im not mistaken, the tsx engine is coded k24a2, which is not listed in the crower's page.. I would assume that the lift durations vary slightly... even if they physically fit, you might run into rough idling/not being able to extract maximum power... just as an example both the 1995-1999 eclipse turbos and all the lancers have 4g63's, but the cam and piston profiles are very different amount these engines even though they share the same engine codes
Originally Posted by MyK24a
naughty boy withg secret project....waaaa, 2.6L stroker kit is no joke man. With cams and hondata, cams and all, it must be an animal. Anyone is the US has done this full loading? What kind of power?
![what](https://acurazine.com/forums/images/smilies/what.gif)
05 6speed tsx!
I contacted Brian Crower and they said that they have a stroker kit that is designed for the k24a2. Would you see any gains with just a reflash and if upgrading to a higher compression would I need to mod anything else for reliability?
the cams intended for the tsx engine are found on the k20a/k20z page http://briancrower.com/makes/honda/k20ak20z.shtml , not he page linked by OP. The stroker kit, STG-2 FI cams and CT supercharger would make for a fun tsx, however getting Hondata to flash an ECU just right with all those items would be tough to hit dead on. Oh the agony of DBW!!!
