Big bore throttle body anyone?
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
I've just purchased a spare TSX TB and spoke with Kingsmotorsports about their big bore TB service. The turnaround time is 2 days (the time it takes to do the work). They will taper, enlarge and polish the TB, as well as replacing the correct size throttle plate. I was told the end result would be just like a factory job. However, they won't be able to set the TPS since it's DBW and no TPS on the TB. Therefore, the throttle angle will need to be verified, perhaps via a scantool for the proper degree of throttle plate opening when closed. I'm hoping the result is similar to my other big bore TB experience, and you can look forward for a dyno test result when available. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Here is a link to Kingsmotorsports.
Originally Posted by BlackTSX
What kind of engine would benefit from this? Any engine or highly modded? And would this provided a good amoutn of HP gain?
A TL drive by wire throttle body is a bolt on. It is 64-65mm. The intake will need port matching and the idle bypass (a left over from the Accord with its standard throttle body) will need welding up.
Based on our K20 tuning, I do not expect much, if any, in the way of gains until the engine is flowing a lot more air. For that you will need a race header cams etc.
However I'll be interested in any dyno results.
Subie Tech
o-qua tangin wann
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
The inside of the throttle body
I'm in the process of preparing the TB and sending it to Kingsmotorsports for the big bore service. Basically, I'm removing everything except the throttle plate and cam assembly. Here are some pictures of what's inside the throttle body.
Throttle body assembly
![](http://www.tsobad.com/jtso/Images/TSX%20TB/TB.JPG)
Bottom covers off - The left is for coolant. The right looks like a venting space for the drive motor.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/Covers.JPG)
Security screw - The drive cover uses T20 security screws with a pin in the center. It also has 6 clips to hold the cover.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/Security%20screw.JPG)
Drive cover off - Note the two pin contacts on the bottom of the cover.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/TB%20drive.JPG)
Throttle actuator control
![](http://www.tsobad.com/jtso/Images/TSX%20TB/DBW%20control.JPG)
Drive assembly - Note the dual springs setup. One to return the throttle pate to home (normal) position. One to return from a fully closed to home (normal) position.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/Drive%20motor.JPG)
Drive motor
![](http://www.tsobad.com/jtso/Images/TSX%20TB/drive%20motor%20assby.JPG)
Throttle plate adjustment points - One at 11 o'clock for fully closed adjustment. One at 5 o'clock for home (normal) position adjustment.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/Adjustments.JPG)
Normal throttle opening - Normal throttle position at rest. the top TB opening is ~ 62.5mm.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/TB%20top.JPG)
Trottle body bottom - The bottom opening is ~ 60.5mm.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/TB%20bottom.JPG)
Misc parts - Parts that I will have to reinstall when the TB comes back from the big bore service.
Drive motor
Received 3,763 Likes
WOW so was it easy to get out and take apart or was it a pain.
God love digial cameras.
I can't go into any exact numbers,etc. but when I was at Comptech and was looking at the TSX SC test bed car I could swear that the Ice box-to-TB looked to be at least half again the OEM size. I didn't ask what they had done to the TB. I'm not fluent in SuperChargereze to ask detailed (i.e. intelligent) questions. Thinking form follows function I would guess the TB or adapted TB assembly would have to be enlarged. How does the SC interface into the TB/Intake assembly and how does the OEM control sys feed into and/or control the SC -- Curious. Any thoughts????
-D
-D
o-qua tangin wann
The KMS Big Bore Throttle Body service is the perfect addition for those who want more intake capacity when using big camshafts, radical headwork and more compression. A new throttle plate is installed and the throttle body bore is tapered, enlarged and polished to fit. Each throttle body is bead blasted for perfect appearance and the TPS sensor is reset for optimum performance.
- From King Motorsports
What mods do you have that would make u wanna get that done?
Drives With Hands
Where'd you find the TB? ebay?
Good luck with this, I'm intrigued.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Originally Posted by rmpage
Do you think a dealer would be willing to do this? Or could most well-equipped garages?
I didn't have dyno results in stages from my previous setup, as I was doing mostly street tuning with the Hondata. I have tried BBK big bore TB and GSR TB on my Civic running JRSC. The bottom opening of those two TBs were perfectly matched to the JRSC intake manifold. They both offered better throttle response over the stock TB, but not sure the amount of gain, or where the improvement was on the dyno curves. But I will have the dyno result for the TSX TB.
so have you gotten it back yet
TB is back!
I just got the TB back from King Motorsports today! The top is enlarged about 4.25mm to 66.75mm, and the bottom about 3.25mm to 63.75mm. A larger throttle plate is installed and plate position adjusted. They really did a fine job on the TB and maximize the size!. The next thing I need to do is to port match the intake manifold opening with the TB before trying it out and taking it to the dyno.
Here are some pics for comparison.
Big bore: Note the taper bore.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/Big%20bore%20TB%20top.JPG)
Stock:
![](http://www.tsobad.com/jtso/Images/TSX%20TB/Stock%20TB%20top.JPG)
Big bore bottom: They put the coating back on just like stock.
![](http://www.tsobad.com/jtso/Images/TSX%20TB/Big%20bore%20TB%20bottom.JPG)
Top comparison:
![](http://www.tsobad.com/jtso/Images/TSX%20TB/TB%20compare.JPG)
Bottom comparison:
Stock:
Top comparison:
Bottom comparison:
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Originally Posted by GIBSON6594
Looks good J, do you think the tapered opening will reduce intake temp at all due to the thinner wall abosorbing less heat?
Originally Posted by CJams
Looks good Johnny! Will you have everything done for the meet on Saturday?
