Anyone know how to adjust the JDM foglights?
Anyone know how to adjust the JDM foglights? The reason am asking is because mine are aimed hella low and I want them to be pointed higher, anyone how to do this CCC, tsx.fury?
Received 3,858 Likes
I am pretty sure they have the same screwdrive whole as the usdm ones do for you to raise and lower it.
Bye TSX, hello domestic?
Originally Posted by TSX.Fury
You guys know he said FOGlights right??
I've adjusted my JDM fogs a few times. Only if you want to REMOVE the fogs do you have to go inside the front airdam. This is a little easier.
To ADJUST all you have to do is look underneath the car right below the fogs. There is a small round hole in the underbody. Put a screwdriver up vertically until it sinks into the vertical adjustment screw (I recommend using a flashlight to find that screw). Turning the screw compresses a spring that angles the lamp in the housing according to how many times you turn the screw.
I have found that it is somewhat important to have your fogs aimed correctly. If aimed too high they will just glare off the fog. If aimed too low then the light will be in too close for driving purposes.
wow I really need to go to bed before I say something wrong again. Good call man. You are completely correct the whole is underneath and the one to remove the fogs is in the airdamn.
No problem. papers suck.
quanaman
01-09-2023 07:33 PM
