Will the 04' TL Rims fit the TSX?
Will the 2004 TL rims fit on the TSX? Does the 04' TL carry the same dimensions and weight as the stock TSX rims? Any clues?
-Spencer
-Spencer
I doubt they are the same, because the TL uses 8" wide rims due to the 235mm wide tires.
I am not sure what the TSX uses, but I heard it is 6.5".
In any case, if the lug patterns are compatible and the off-set is within 5mm of each other, the TL rims should fit. However, they will likely be heavier, and you'd almost necessarily have to get wider rubber to fit the wider rim.
The 2003 TL-S wheels will fit, being that they have the same offset, but the 2004 TL will have 17" x 8" wheels on it. I doubt they'll fit, being that the TSX has 17" x 6.5" wheels on it. The tires on the TL will also be 235/45/17s.
acura_dipset_tl
01-01-2016 03:02 PM
nuldabz
09-03-2015 05:49 PM
