Why am i only getting 17.6 MPG?
Old 06-24-2008, 10:22 PM
  #41
Make a hole, coming thru!
davidspalding's Avatar
I'm not a fuel engineer, but...
Originally Posted by spoiledkari
How do you figure?? The more water in the gas...the less actual gas you're getting per gallon. So...yes...it does matter!
If I mix 2 oz of water in with 10 oz of Coke...I'm technically getting 12 ozs in my glass but only 10 ozs of it is Coke. It's diluted. Same concept with gas. It gets diluted and you get less per gallon....
I think that Toyota guy was repeating a myth. Water does not dilute gas. Having done hundreds of morning fuel samples on avgas (aviation gas) from jet aircraft fuel tanks, I can assure you they don't mix ... so the octane of a fuel couldn't be "lessened" by some water in the tank.
If high compression auto engines are anything like aircraft engines, a little gas in the fuel can cause pretty serious problems.
Old 06-24-2008, 10:26 PM
  #42
Mokos23's Avatar
yup i agree
Old 06-24-2008, 11:28 PM
  #43
LukeaTron's Avatar
More basically than that, what I meant was that the octane rating of gas is a measure of it's ability to resist spontaneous combustion from heat and pressure. Nothing more, nothing less. Water won't dilute the gasoline or alter the octane rating in any way. What you're Toyota tech told you doesn't make any sense.
Water in a high compression ratio engine - and it doesn't get higher than an airplane engine - is bad because it doesn't compress. A small amount of water going into an engine like that could easily destroy it.
marinrain
ILX
10-06-2015 12:36 AM
Froid
09-27-2015 06:16 PM
ceb
ILX
09-27-2015 10:56 AM
TL14
09-24-2015 04:37 PM
vbgregg
09-11-2015 05:38 PM
Quick Reply: Why am i only getting 17.6 MPG?
