Weak battery?
Weak battery?
I know that many people have said that the stock battery is pretty weak. Tonight I was waiting to pick someone up, so I had the engine off but was running the radio, parking lights, and seat warmer (on low). After 20 minutes, my battery was completely dead! I figure that the seat warmer puts quite a strain on the battery, but would that kill it in only 20 minutes, or is it time for a new battery?
I have a 2004 with 47,000 miles on what I think is the original battery.
RGSTRD TL & TSX Offdr
The seat heater sucks way more juice than the lights. It's not the least bit surprising that having all that stuff on killed the battery. I wouldn't be too worried about the battery based on that.
Book says that the seat heaters suck battery fast:
Use the HI setting only to heat the
seats quickly, because it draws
large amounts of current from the
battery.
If the engine is left idling for an
extended period, do not use the
seat heaters even on the LO
setting. It can weaken the battery,
causing hard starting.
Geez when can you use the things, only when moving? Not while idling, not while ignition is off, ONLY when driving. That kinda sucks.
battery.
MetalGearTypeS
08-29-2016 08:28 PM
