VSA and winter
I don't know much about the VSA, but my salesman told me in a snowbank or going up hill in the snow, shut it off. You will continue to spin the tire that is slipping.
Re: VSA and winter
Originally posted by lgregoir
If you're stuck in a snow bank, will the VSA keep the car from spinning one wheel only (a bit like a viscous coupling)?
tires spinning is a traction control issue...and all the VSA will do is cut power. So it wont matter whethere its 1 tire..or 2 tires spinning..all traction control will do is take off some power.
such a dirty birdy
Not quite. What you're describing is a limited-slip differential. As I understand it, in the scenario you describe, VSA will brake the spinning wheel and perhaps close the throttle a bit. The throttle modulation only happens if you're moving I think (understeer detected). If you're stuck in a snow bank or trying to start from a stop on ice, turn the VSA off.
from Acura
The Traction Control System (TCS) component of VSA uses sensors that monitor the front wheels and computer-controlled modulation of engine power and front brakes to help prevent wheel spin when starting out or accelerating. If the sensors detect excessive front-wheel spin during acceleration, TCS automatically closes a secondary throttle valve until wheel spin stops. This helps the TSX maintain traction during acceleration and helps the driver retain steering control, even when accelerating on slippery surfaces.
Jamus22
06-11-2023 10:08 AM
