Type of gas to use
Originally Posted by domn
Or if you're too lazy to read those:
Use 91 or higher no matter what. If you use lower octane fuel you will run the risk of not only a knock, but also the fouling of your plugs and clogging of your injectors. Your fuel economy will also take a hit, as the car is intended to have a certain level of octane for its combustion. We had a customer in not too long ago that tested it and was burned. He had top not only flush the fuel system, but also had to replace his plugs. One did it just once and got lucky enough that he only had to run new fuel through the system. Don't take your chances just because you think you're saving a couple cents per gallon. Losing fuel economy and running the risk of damaging internals will cost you more each time.
Locking this thread, as your question have been answered. Also, don't hesitate to you use the search link that jlukja has provided if you have any related questions (there is a lot of good info related to this topic on this site-feel free to look around).
OculiAquilae
11-19-2018 02:24 PM
sockr1
10-01-2015 01:31 AM
