TSX Engine - K24A2
TSX Engine - K24A2
As much as I am upset about the constant rattles, I really cant say enough about this engine. Do you think there is a better a 4 cylinder engine out there? I doubt it. If there is its probably another Honda engine....perhaps the s2000's? The refinement and power in a 4 cyl like this is pretty amazing. At 6,000 miles it still feels like its getting "loose." Someone once stated that Honda basically is an engine builder that looks for things to put engines in...the more I drive this car and the more I hear about Honda building pickups (Ridgeline looks awesome) and corporate jets, the more I believe it!
I think there are better 4 cylinders out there yes (All Hondas) but this is definently the perfect 4 cylinder for this car.
Having said that it could use another 20 to 30HP.
I spend 2 much time here
Audi Driving Snob
Originally Posted by jiggaman
could 20 or 30 more HP really be achieved from the factory without reliability issues?
what engines make that? or what cars have that?
Are you guys serious?
You do realize the S2000 has 240HP from a 2 and now a 2.2L. The RSX-S has a 2.0L 200HP/210HP motor and the current Integra Type R and AccordEuro R both have the 2.0L 220HP motor.
noo i ment that u said they were waiting to release the program, they prolly know that the 2.4l can put out much more than they are getting right now. that and that the engine and ecu is very advanced... atleast i would hope. but with the new RL out i would hope that they are sharing pointers between eachother
Lola
mines pretty loose and i just racked on the 8000th mile a week ago. she still pulls hard as ever but i drive her every day, im trying to get my dad to give me input on wether it changed much cuz he drives it once ever month or so. but he drives like an old man and i dont think he knows what a "butt dyno" is....
eh, she keeps my buisy. i wouldnt worry i dont have any rattles cept for some of the interior ones but they come and go. i dont let it bother me much any more, just turn the radio up if they come back cuz i kno theyll leave like they came
Originally Posted by nightdriver
How bad are your rattles? Do you feel your experience is in the minority or do other TSX owners you know have rattles issues? Thanks.
Lets see...when I bought it I found that the plastic around the shifter (I have a 5AT) creaked. Took to dealer who replaced the plastic but it still clicks now and then even after I put some rubber "shims" in there. Now I have another clicking noise coming from the console and I have the dreaded windshield creaking noise coming from the passenger side.
I actually think this is pretty much the norm. Those that dont have the windshield issue probably live in climates that are more mild than where I am. It kicks in around 35 degrees.
I think my drivers seat may be starting to move slightly when I make abrupt stops but I am not sure.
These issues I believe are pretty typical and can be seen in the problems and fixes area. My dealer is pretty poor so that is part of the problem too.
The car is a great car....the issues I mention here are probably exagerrated as most people without issues dont post. I wouldnt let them stop you if you are in the market to buy.
Driver/Detailer
Honda's speciality is in making engines that spin faster. When NA engines spin faster, they make more power for the same torque. Now the K24A2 is a good engine, but by the undersquare design, it cannot spin any faster without using Nikasil coating and balanced pistons. Unless they pull the K24A2 apart and hand polish and balance and get the block redesigned for Nikasil (because it is thinner than the iron sleeve), it is difficult to get more power from the K24A2 apart from FI. I guess the compromise that Honda did with the K24A2 was that given the limitation for power, they instead decided to make it smooth throughout the entire rev range.
As much as I am upset about the constant rattles, I really cant say enough about this engine. Do you think there is a better a 4 cylinder engine out there? I doubt it. If there is its probably another Honda engine....perhaps the s2000's?...
Moderator Alumnus
Originally Posted by indydriver
If you do a search of early discussions on this board, you will find a lot of interesting stuff on the K24A2. First, it is a heavily stroked version of the two liter, making it a very "undersquare" design (i.e., stroke larger than bore). This results in very high piston speeds (one poster ranked it #9 of all mass produced engines!). This suggests there isn't a lot left in this particular design. Probably won't be too friendly (reliable) to aftermarket forced induction. Enjoy it for what it is and don't try to make it something more appropriate for a different platform.
https://acurazine.com/forums/showthread.php?t=13223
Stardog Champion
It is a great engine, but what's holding it back is the weak fuel map program. Tuned for economy, not performance.
I believe the compression ratio on the S2k (11.5:1) is also higher than in the TSX (10.5:1) That bump in compression alone will gain the 20-40 hp the TSX is missing.
Originally Posted by Karl O.
I think people are already getting 215 whp out of the TSX engine without much ECU tuning and without raising the rev limiter, just a bunch of bolt-ons. That should equate to 240+ at the crank. With lots of ECU tuning I don't think 250 HP at the crank is out of the question. At that point you're going to spend so much time spinning your inside tire without some sort of LSD that more power is not going to be helpful.
Link. I don't think anyone has come close to 215 WHEEL HP?
On a 6MT TSX that would work out to be an increase of 60 +/- crank horserpower given a 15-18% drivetrain loss. It would also put the TSX around 14.5 @ 93-95 MPH (based upon weight vs. hp) and I don't think any TSX has hit those numbers yet.
Audi Driving Snob
The poster was misinformed.... though we have seen a dyno of a k24a2 that hit 215 whp. A base rsx user swapped a stock tsx motor into his ride and gave it the standard i/h/e treatment along with fuel/vtc tuning with his hondata kpro. Swapping the motor elimintaed the drive by wire system which has been the sticking point thus far for hondata.
With i/h/e and tuned ecu he hit 215 hp and 181 lbft torque at the ground and supposedly this with an untuned low cam.
Here is the best dyno we've seen with the stock ecu.(i know stokeless had a better hp figure but the torque curve on this one is sweeeet)
With hondata the tsx is going to be the car everyone wanted in the first place.
Originally Posted by sauceman
Interesting to compare these actual dyno runs to the power curve in the 2005 brochure. According to Acura, the VTEC dip doesn't exist. It is clear from every dyno run posted on this site that there is a noticeable dip in power at 6,000.
Moderator Alumnus
Moderator Alumnus
Yeah, that's it. That was a great post Sauce. I'm curious, where did you find that info and how do you know that it was all inclusive?
If you search, you can find a few sites that will have a piston speed calculator. You just need to add in the specs, and voila!
Driver/Detailer
Increasing the compression ratio, aggressive cams, upgrading valve springs and lightening the valves, pistons and conrods won't do much. It will increase the max torque point to a higher RPM, but the engine won't be able to spin any faster to take advantage and make more power.
Power = Torque x RPM
____________5252
You can only increase power by increasing either torque or RPM. Since RPM is limited by piston speeds, then you have to look at increasing torque.
Moderator Alumnus
Audi Driving Snob
Bolt ons will of course work fine on the K24A2 because it improves cylinder filling, and hence increase the torque slightly in the upper rpm range. I was talking about AFTER bolt ons. The ECU might give you a bit of extra if it is tuned rich from the factory, but that is it. Bolt ons and ECU.
____________5252
____________5252
cycdaniel
12-17-2019 10:58 AM
