TSX 0-60/1/4 mile Times Thread
#81
ET's are mostly just driving skills (or maybe how hard you're willing to beat on your daily driver). Trap speed is a more reliable indication of power, and I've seen an 06 manual TSX hit 96-97 mph NA power roughly at sea level and 75*F. Didnt ask if it was pump gas or not. His times were pretty good though...mid 14's IIRC.
#84
15.7 at 95mph at Orlando speedworld at around 85 degrees- 09 tsx 6mt... Wheel hopping like crazy too
Wishing they came with LSD
#85
#86
next time you go let some air out of the front tires to about 20-25 psi itll help with grip and wheel hop a little. stiffer mounts will take wheel hop out but will be a pain to dd. 70-75a reduces a lot of wheel hop and is still ok to dd.
#87
Can't dd below 30 pounds or my tpms sensors go off.. Tried that at the track already once and couldn't turn the vsa off.. Unless I want to ride the clutch coming out of 1st and soft shift into 2nd gear (which defeats the whole purpose of letting air out) the vsa will kick in and my time will be shitty regardless :/
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
