To those who installed their own fog lights
Previous post said Fog light switch/lever install was different than that posted on instruction sheets. How so? How was the upper and lower portions of the the steering colum cover seperated tp gain access to switch/lever? Is there a "trick" involved (push - twist - pinch something else?) Can't see paying a service department that kind of money. Thanx
the level is different because it has a on/off switch that turns to power the fogs. the upper and lower portions of the steering column cover come apart by squeezing the sides of the top portion.
My other "car" is a 4x4
The instructions I used (pdf on hondacuraworld.com) were totally accurate, although perhaps not as detailed as some would prefer.
To remove the cover, adjust the steering wheel so it's fully telescoped, but don't re-lock the adjustment lever. Remove 3 screws from the bottom, then apply pressure to the seam of the cover, where each of the 3 clips per side holding the halves together are located. I don't recall whether the top clips into the bottom or the bottom clips into the top (i.e. which half has female ends) so refer to the diagrams on the instructions. This will help you put pressure on either the top or the bottom while you pry the halves apart. Pry apart gently but firmly. I started with the front left clip (the one closest to the turn signal lever).
Re: To those who installed their own fog lights
TSX-Black Bolt
Where to get PDF
I went to hondacuraworld.com, but could not find the install PDF.
Can someone send a direct link, or is there a more detailed one some where else?
Forestsoft
Forestsoft
UK Spec
i read from a post here b4 i did the install last week...
forgot who posted it..
but he told me to buy gloves
and so i did... MUAUA thanks man!!!!!
i would suggest u to do the same... omg the grease on the fuze
box yeah so just get a pair of 10cent rubber gloves... maybe one
for ur friend if he's helping u.. h'd thank u a lot as well
here u go
fog light install
here u go
fog light install
UK Spec
Re: Cool
Originally posted by forestsoft
Thanks for the feed back , I will go pick up the gloves today.
How long did your fog light project take?
the intake box and the switch install was a b*tch
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
