Service Manual - "Hidden" Diagnostics
Central Scrutinizer
After leafing through the 04/05 Service Manual, I came across a couple of diagnostic modes that you can enter without hooking the car up to the Honda Diagnostic System. I haven't tried this on mine yet (just got it a couple of days ago), but give it a try and let me know what you think...
From page 21-11 (Climate Control section):
The climate control unit has a diagnostic mode that allows you to view sensor inputs that it receives. To run the sensor input display mode:
1. Turn the ignition switch off.
2. Press and hold both AUTO and DUAL buttons, and start the engine.
3. After the engine starts, release both buttons.
4. The audio-HVAC display will flash a sensor number, then value for the sensor.
5. To adavnce to the next sensor, press the rear window defogger button.
6. To cancel this mode, press AUTO, or turn off ignition.
Sensor numbers, descriptions, and display values as follows:
1. In-car temp (degrees C).
2. Outside temp (C).
3. Solar radiation sensor value (00=dark, 10=cloudy, 65=sunny).
4. Engine coolant temp (C).
5. Evaporator outlet air temp (C).
6. Driver's air mix opening (low=cool, high=warm, %).
7. Passenger's air mix opening (low=cool, high=warm, %).
8. Vehicle speed (km/h).
9. Vent temp air out (C).
That's right - you have a digital speedo in your car!
You'll have to convert degress Celcius and kilometers per hour if you are in the good ol' USA.
Have fun!
Scott
Have fun!
Scott
I'm the Firestarter
Isn't there an easier way to get the current in-car temperature??
Central Scrutinizer
Thanks Dan!
There's an even COOLER one on page 22-218 (Guage section) that will cause your gauges to do a full sweep test, among other things (LCD checks, switch checks, etc).
Its just a lot hard to explain and I'm too lazy to type it in. Perhaps a scan is in order...
Scott
Scott
Central Scrutinizer
Originally Posted by MemRheins
That for Navi only? or does it work for the rest of us, lol interested in the digital speedo
Scott
I'm the Firestarter
Originally Posted by Mr.Sparkle
YUP! And the outside temp too!
I thought folks might be interested in the other stuff...
Central Scrutinizer
Originally Posted by Belzebutt
No no, my question was, is there an easier way to get the inside temp, like while you're driving. This method forces you to turn off and on the ignition.
The method mentioned above was the only one that I could find in the manual.
Scott
just tried this out, not a bad find...please do post the instructions for doing the gauge cluster sweep test, it would be sweet to have the gauge cluster do the sweep test everytime you start the car...
Computer Nerd
I tried it too, too bad it keeps blinking between the senor number and then the sensor value. I thought it would display both the sensor number and the value so the digital speedo can actually be read. I guess not.
Central Scrutinizer
I'm here! I'll try and scan the pages tonight.
Don't get too excited... The full sweep guage test can't be set to run every time you start your car (at least not according to the manual). There's quite a lengthy sequence of "to do's" to get it to run. Stay tuned!
Originally Posted by CGTSX2004
I just tried this out too. I couldn't get the diagnostic mode to stay on after starting up the engine. It would only work for me when I placed the ignition switch to ON...
weird, i held the buttons down, turned on the car and then let go of the buttons...i was driving around with the diag mode on...
Central Scrutinizer
Here they are! The scans are low quality, to keep the .JPG size down:
Service Manual Page 22-218
Service Manual Page 22-219
Just curious... Is there an easier way to host these files than on my own WWW space?
Enjoy!
Scott
Enjoy!
Scott
Enjoy!
Scott
Enjoy!
Scott
And many members use imageshack.us to host pics. It's free.
Central Scrutinizer
Originally Posted by observer
Thanks for the info, Mr. Sparkle! But I'd just like to point out that the speedometer unit is not km/h, but 10 km/h.
That doesn't make for a very precise digital speedo, now does it?
I still have yet to try all of this stuff myself!
The manual doesn't reflect that. Hmmm...
Central Scrutinizer
For reference, here's the original manual page regarding the sensor testing:
Service Manual Page 21-11
Hey, I tried to do the gauge sweep thing but it doesn't work . . .
I turned the ignition to ON with the RES and headlights on, and did the lights off, on, off, press RES 3 times sequence, but didn't get any indication that I'm in the self-diagnosis mode. I tried pressing the RES switch but was unable to get the sweep.
What's confusing in the diagram on page 22-219 is that I'm not sure what the 5 beeper signals at the beginning corresponds to. When I first turned ignition ON, I do hear 5 beeper signals, but that's before I did the lights off, on, off, RES 3 times sequence so according to the diagram on 22-218, at that time I couldn't have been in the self-diagnosis mode like 22-219 suggests.
Anyone had any luck with this?
Oh, I think I know what's happening now. I was pressing the wrong trip/reset button! I thought it was the the cruise control RES button on the steering wheel, but I think it's really the button on the dash. Lemme try again . . .
Originally Posted by Bootlegged
Can someone please clarify what the gauge sweep actually does? I'm confuuuused
Gage sweep forces the gages to travel their entire arc. i.e. the fuel gage will go from indicating totally full to totally empty.
Originally Posted by jlukja
Why, it cleans out all the dust out of the gages. j/k
Central Scrutinizer
But for this to occur, the driver must perform those step by step actions every time they start the car right? Or is this a one time setting where the gauges will automatically travel their entire arc. continuously FOREVER and EVER!!
Go Giants
Are you guys breaking your car?
Git er Done!!
So I did the gauge cluster test and it worked fine, but I got an "Error 2" message. Can someone look up what that error means? On the second page that was scaned it said for and Error 2 message go to page 22-77. What the hell could be wrong with my car? Could the car possibly be seeing that the factory amp is no longer in the car?
