Rumour Mill: Turbo for nex-gen TSX
#81
Originally Posted by jcbridges
This will also coincide with the TL re-design (Fall 08) for 09 model year with AWD as definite and 3.5L and a mid-model re-design on the RL.
V8 for the RL???
also touch screen for the navi... the TL and TSX interface it so much nicer than the others...
#82
I am an Acura dealer and have had confirmation from our rep that the TSX re-design will be for the 2009 model year. AWD is definite and so is the turbo (not sure if that will only be on Type S or not). RSX will come back same time as TSX Coupe. I have also been told this release will happen earlier than Fall 08, and more along the lines of the original TSX release (Spring 08)
Hmmmm...Very skeptical about that RSX part.
#83
I dunno about that. AWD I can see, though. However, I don't really want a turbo unless there's a NA option too. I'd rather have a 6 cyl than a turbo 4.
#84
Forced induction cars produce massive torque (comparatively speaking) very low in the RPM range.
I wish I had a RDX dyno handy, but the VW 2.0T motors produce over 200 lb-ft of torque even below 2000 RPM. This is 20% more than the peak torque of the TSX and probably 30-40% more than it produces at the same RPM. It takes a big V6 to generate the same torque at those RPM.
A turbo with proper gearing and matching the drive-train with the car gives I-4 driving character and economy most of the time, and V6 performance when you need it.
#85
Originally Posted by rb1
Well, you might want to wait to pass judgement until you drive one when it comes out.
Are turbos any more expensive to fix than a NA engine? I honestly don't know much about turbos, but have heard they're not as reliable as NA engines, and more expensive to work on.
#87
Turbos are slightly more time consuming to mod, cause you can really mess stuff up if you dont know what youre doing...but anyone that says they would rather have a heavy V6 opposed to a turbo 4? Have you ever seen the numbers on the Evos and STIs? both still maintain 25-28 mpg range on highway driving and massive amounts of torque. If they make a decent turbo with the 4 banger, Im down, cause you can mod the hell out of the intercooler and turbos to your hearts content. With NA, you have less options but much easier bolt ons.
Im not skeptical about the RSX comeback, Acura said that all along that it was rebading as a TSX coupe. Now if its AWD and turbo is the question.
#88
The engine itself really isn't any different, although typically it would have a lower compression ratio than what you see in the TSX and usually a large capacity cooling system. Effectively, force induction raises the apparent displacement of the engine. If you have a 2.0L turbo engine with boost of 0.5 bar (very conservative, a hair over 7 psi), then it can burn as much gas (and crank out as much power!) on full boost as a 3.0L engine, so the cooling system needs to be sized larger.
However, unless you're accelerating, driving uphill, or driving fast (70+ mph), a turbo isn't generating any boost anyway and the engine pulls a vacuum just like any other NA car.
I think the reliability issues have been largely dealt with, but a turbo won't tolerate poor maintenance, especially low quality oil or excessive oil change intervals. The exhaust side of a turbo gets hot, and a turbo spins very fast when on boost (100,000+ RPM), usually floating on an oil bearing, so you need good oil. Turbo's are always water-cooled now, so there isn't a problem with this heat when driving.
Given Honda's reputation for reliability, I can't see them putting one in a car unless they are willing to stand by it.
#89
Yeah, I understand what you're saying, but I don't want the mpg that the RDX gets. The TSX is lighter I assume, so maybe it wouldn't be so bad, but I just don't want 17mpg or something because that would be horrendous.
As rb1 as said you need to change your oil and not leave if for extended intervals. Other than that the reliability of turbo engines are very good. Forced induction as been around for a long time and new ideas are always coming forward. Look at the 1.4L twincharger VW has in europe. Supercharged and a turbo, it puts out 170 hp well over 200 tq and about 15-20% better fuel consumption than a NA 2.3L engine....thats pretty impressive for such a small engine.
#90
Originally Posted by cp3117
The 2.0T Jetta is close to the same weight as a TSX and actually has slightly better fuel consumption ratings. I believe FSI also has a factor in this along with helping the very minimal turbo lag.
(FSI is a technology for controlling the fuel dispersal in the cylinder. One benefit is the possibly to run the engine on a very lean fuel mixture from an A/F ratio perspective by concentrating s small fuel vapor "cloud" around the spark plug. Very fuel efficient.
http://en.wikipedia.org/wiki/Fuel_Stratified_Injection)
#93
One of the things that I really like about the TSX and the TL is the re-sale value. I think that having a turbo will really hurt this. My understanding is, at some point in the life of the car, the turbo must be replaced for high $$$. This was the case in the past. That is one reason why turbos came and went in the 80's. I don't know if present day turbos are any better. Basically, you can't give away a 10 year old car with a turbo unless the turbo has already been replaced.
#94
This all sounds like bullsh*t to me. The next TSX will be out this fall as a 2008 model, whether or not it has a turbo is still the unknown.
The dealer chap above does not know what he is talking about.
#95
2008 TSX vs 2008 Eclipse GSX
If the TSX comes out in a coupe, then it will have real strong competition against the 2008 Eclipse which is also rumored to have AWD plus a turbo bringing the total HP above 280. It probably will not be as refined as the TSX, but it will be an alternative to those who can't afford a G35. But I'm guessing price-wise the 2008 Eclipse and TSX will be real close...
#96
I agree there was more problems in the 80's with turbo cars, but this was mainly due technology and education especially with North American cars and consumers.
Synthetic oil was just new to automotive's then and was considered a overpriced hoax. I dont think manufactuers even reccomended it for turbo cars back then. Things like letting the engine/turbo cool down for a minute or two after a spirited run before shutting it off...changing the oil regularly....using synthetic oil etc all helps preserve a turbos life. Its just like anything, if you look after it and not abuse or take it for granted it will last a long time.
Also in the last 20 years improvments in parts, seals etc has all improved so the quality/reliability is much better.
#97
(Dunno what a TSX clutch costs to replace, but a turbo can easily last 100-150K miles)
#98
My question to the turbo guys is, what's it like at 150k miles? I've had 2 hondas and a BMW in the 150k range, and they still revved like champs. I kicked the snoot out of those cars everyday on a 50+ mile commute in the the Los Angeles area. The engines were as sweet the day I sold them as they we're on mile 40,000.
My only point of reference for turbos was my sister had a '02 S60 T5 Volvo whose acceleration was decidedly laggy and whose characteristics changed well before 100k miles (dunno if it truly had to do with the turbo though).
#99
Says who?
A letter from Acura to dealers has already been posted online that outlines 2008 ordering begins in May. So unless the all new 2008 TSX debuts next month, the 08 remains unchanged.
#101
Says who?
#102
I wonder if BMW is worried about the 335's resale? I doubt it.
#103
...but current TSX owners might not be too happy as the resale value will probably hit them hard. Especially if the second generation looks alot different too.
We current owners could only wish (at least as far as values are concerned)...
#104
Originally Posted by JeffS
Resale isn't BMW's issue with the 335, it is fuel pumps. There are many posting on bimmerfest about them breaking and replacements being on backorder from BMW. Surprisingly most of the owner's are taking a oh it such a great car that I don't car that I can't drive it till it is fixed attitude. It is kind of amusing though.
#106
When that twin turbo 335i goes out of warranty, the re-sale value will drop like a rock. Just wait and see.
We'll see. Didn't know about all those problems the 335 were having.
Thats why I'll never buy a first year model again. I'll bet the 08+ 335 will be alot more reliable.
#107
This sounds correct as the 08 TSX's will be the same, but the 09 will be the redesign coming Spring 08.
I'll be my left testicle the TSX remains unchanged for 08. Hell, I'll throw in my right one as well.
#109
http://www.brucegilbertmd.com/services_testpros.html
#112
Oh wait, Yes I do, Yes I am and Yes I have...........
#113
You're absolutely right, I don't have any access to information that the general public does not. I am not in regular contact with our Acura rep about product development. I have not already received 08 ordering info from Acura.
Is there a chance that there will be a TSX Type S for the 2008 model year before the re-design?
#114
Your the second or third person to say something about this so I'd like to think its confirmed that the 08 remains unchanged.
And I have no idea why people think the TSX will be all new for 08 and are so shocked to hear that it won't be.
I've been saying spring of 09 for quite some time now so that should have been all the proof they needed.
#115
#116
Originally Posted by CarbonGray Earl
On a side note, I wish Acura would release the Type-S trim on the second or third year of a product's life cycle, rather than in the last year as a last hurrah for that model. It kinda sucks for those TL Type-S owners who have bought it, only to have their vehicle trumped by the next "base model" TL the following year.
They do it to increase sales and to keep customers interested before a re-design. Current sales of the TL and TSX are lagging. This is why there is a Type S version of the TL and 1.9% financing. I suspect we will see something similar, low financing or a Type S, for the TSX soon.
#117
Tsx Headlight
Does anyone know how long it takes to fix the headlight? I was talking to HONDA customer service regarding recall on the engine and she told me I am ok with that but need to come in for headlights. I heard it gets fogged up. It's so funny because mine just got fogged up. I wonder if they replace them or just fix them.
#118
Also, the Type S hold their value much better as they are very limited production.
#119
Acura puts out the Type S for the last 2 years of the TL MY cycle (TL 02-03, TL 07-08)
This would look more like an enthusiast based decision rather than sheer market manipulation. BMW's M division, AMG, even Mazdaspeed gets a high performance version out quicker than Acura does. In Europe, a Civic Type-R is already available, a year after the new Civic hatch was launched, so Honda isn't unfamiliar with this. The same goes for the Civic and the Civic SI here in the States. I believe this would be as good a strategy for Acura as it is for everyone else.
#120
https://acurazine.com/forums/car-talk-5/
