Rumour Mill: Turbo for nex-gen TSX
#41
Originally Posted by savage
i heard from my cousins, neighbors, dog walkers, uncle who knows a guy at Honda that the next gen TSX will have a inline 6, twin turbo, and RWD...
Are they gonna call it the TSX 335i?
#43
Originally Posted by mg7726
it all depends on the price, if acura overprices the TSX like the TL-S, that would suck. souped up model should not be over $33k.
base should be under $30k, *cough* $29,999. just to keep the fan base
#46
Driver/Detailer
Originally Posted by junktionfet
Haha... that's quite an assumption--that's over half an inch decrease in stroke! Take it down a notch. A mild bump in displacement can easily be had with a mild drop in stroke and increase in bore. And please resist the temptation to negate my humble opinion again, and try assuming this time that the changes I'm suggesting could fit within the existing K series block. Thanks!
#50
Originally Posted by aaronng
LOL, if you want to stick to a piston speed of about 4500 ft/min, then you NEED to destroke it to 86mm. At 99mm, 7000rpm, the piston speed is 4547 ft/min. When destroked to 86mm, 8000rpm, the piston speed is 4514 ft/min. Fine, you can have 87mm, which gives 4567 ft/min. But that's about it for a mass-produced engine. If you want to go any higher, you'll looking at FRM/Nikasil liners, not cheap on a mass-produced engine. 90mm stroke @ 8000rpm, isn't going to happen on a mass-produced engine. You'll need lightweight and coated parts for that which means the cost will go up. Since you guys don't want to pay 10k more over the current price of the TSX, I don't think Acura will go this route of a new block or use reinforced internals.
#51
Driver/Detailer
Whoa tiger... Why are you fixated on an 8000 RPM redline? And more importantly, why do you use that as a vehicle for rebuttal? I've never requested something so lofty. "LOL" is correct.
#52
I'd like to see a larger 4 cylinder than the current 2.4--preferably one that gains its extra displacement by an increase in bore (and perhaps a drop in stroke).
The 1.8T was smooth mainly because it was small (and the dual mass flywheel also helped).
#54
236 hp for the Porsche 968 -- http://www.968.net/images/images/968...al_data_01.jpg
#55
Please No 2009
Acura really should tier their products. They now have the TL & TSX as 2004-2008 & the RDX & MDX as 2007-2011. 1 per year would keep the public interested in their product line. Since TL sales are on the decline while TSX is still going up, I would change the TL 1st but if they go w/ the European Accord schedule, the TSX would be due next year {altho I have heard rumblings that the next TSX is not going to be the European Accord}.
The TL is due for some major improvements especially since even the Lexus ES350 has more HP. This gives the TSX @ least room for optional power like a turbo, hybrid, diesel or 6 cylinder. Hopefully this will silence all the complainers of Acura offering sub-entry level luxury cars.
#57
I think porsche did make a 3.0L I4... but they only got 200hp from it because it couldn't spin at high rpms while still being stable.
Piston speeds aren't as much of a limiting factor like they are in a Honda-centric world because the Porsche engine's displacement comes from a vastly oversquare design (104mm bore, 87mm stroke). The careful design of the pistons, cylinder head, and balance shafts all kept the ginormous 3.0 liter 4 cylinder very smooth at high RPM. It is probably still the best large displacement 4 cylinder engine ever made. You get what you pay for.
If the balance shaft belt jumps a cog... then it isn't so smooth anymore. Feeling a deliberately unbalanced 3.0 liter 4 cylinder is quite a experience.
#58
Driver/Detailer
I still prefer the E30 M3 EVO's engine though.... 238hp from a 2.5L inline4 with no lack of low end. That was a beauty.
#59
Engineer
#60
She said: it's GINORMOUS!
From an OZ article:
http://www.goauto.com.au/mellor/mell...2572A300813123
NOOOO! where is my 2.3T engine, aarrghhh!!!
at least they ain't putting a V6
Details are sketchy, but GoAuto understands the Euro will have very similar styling to Honda’s 2005 Tokyo motor show car, the Sports 4 Concept, along with a larger 2.5-litre four-cylinder engine.
#61
John Starks - The Dunk
From an OZ article:
#63
mrgold35
I think Acura should offer more engine choices and let the public decide on what they want. You don’t get any engine choices with none of the current brands except for the TL and the Type-S TL.
Hey Mr. Acura, gives at least 2, 3 or maybe 4 choices from the list below, with or without sh-awd:
- 2.2L-2.5L turbo diesel engine
- 2.4L I-4 High output (current engine)
- 2.4L + Hybrid
- 2.3L Turbo
- 3.0L V-6 High output
- 3.2L V-6 High output (upgrade all TLs engines to 3.5L and 3.7L for Type-S)
The TSX would have out sold the TL if it had a 3.0L V-6 option since 04.
- 2.4L + Hybrid
- 2.3L Turbo
#64
for some reason, I believe the next innovation is going to be in transmissions. while horsepower may remain pretty close to the base models of other entry level sports sedans, I think Honda is going to introduce some interesting transmission technology, first with the incoming Accord and TL, and then the TSX. Of course, the differentiation with Acura and Honda will be SH-AWD.
Temple of Vtec had an interview on the new accord design with some head honcho, and one of the things he couldn't discuss was the transmission when asked specifically about it. Its a typical signal from honda that something is up.
#65
Found this over at TOV
So the 08's will be in early to make room for an all new 09 TSX in the spring of 08
As far as an innovative transmission goes, I don't know. We haven't heard a peep about it. I imagine some from of DSG style transmission from Honda at some point but thats not really innovative. The beans were spilled on their new A-VTEC so you'd think we'd have heard something about an all new tranny by now as well. We'll see.
"2007 TSX
BUILDOUT - This is the final allocation for MY07 TSX. The MY08 TSX will be available on the next allocation (May MOVE allocation).
The following color will no longer be available for the 2007 model year TSX: Deep Green Pearl (GG/PA). This color is currently scheduled to be offered again for 2008 model year TSX in August 2007, and the remainder of the 2008 model year."
#66
#68
But again, we can only speculate.
#70
...I imagine some from of DSG style transmission from Honda at some point but thats not really innovative...
Also, it's evidently quite heavy.
Honda’s I-SHIFT only debut recently on the European market Honda Civic hatchback, pairing it with the 1.4 liter i-DSI engine and the 1.8 liter SOHC i-VTEC engine. In fact, there is another automated manual transmission on the market with a similiar name - Volvo’s i-Shift used on it’s trucks and buses.
The Honda I-SHIFT is a 6-speed manual transmission with a hydraulic computer controlled clutch. The I-SHIFT transmission is a 700 pound option over the Civic with a standard 6-speed manual
#71
Originally Posted by txhothead
A turbo would be the kiss of death for the next generation TSX. Hopefully, Acura has learned from their mistakes like the RDX. The TSX really needs a small (2.5 - 3.0) liter V6.
The mistake was putting a small-block, high boost turbo motor in a 4000 lb vehicle and charging $33000 for it, and getting predictably lousy fuel economy since the smallish engine has to run on boost all the time to power such a large vehicle.
Drop the compression ratio in the TSX to 9.5:1 or so, add a lower boost turbo (although I'd vote for supercharger actually -- much simpler mechanically and more emissions friendly), and weeeeeeeeeeeeee!!! The TSX motor is easily capable of 225 lb-ft of torque (or more, but watch torque steer) and 250+ hp with just mild boost.
#73
Audi, VW, Volvo, Saab and Subaru do just fine using Turbo's in their mid size sedans.
#74
The only thing I have a hard time believing is the fall of 2008 release.
And I have to think there will still be a "base" NA TSX available without SH-AWD. A Turbo SH-AWD TSX will simply cost too much for the target market. But will be ideal as a Type-S.
And I would hardly call this "confirmed".
like you said, i hardly see acura offering 2 engine configs (unless they did a type s) on the tsx w/ the way their model structure goes.
#75
Evidently, Honda already sells a DSG type transmission in Europe. The Honda I-Drive.
http://paultan.org/archives/2006/08/03/honda-i-shift/
#77
Originally Posted by JoeC1982
pretty sure thats 700 pounds as in the currency, not weight.
Mea culpa-- you're almost certainly correct. A traditional automatic is somewhat heavier (100ish lbs), so I should have realized this wasn't right.
#78
Driver/Detailer
#79
It's True!
I am an Acura dealer and have had confirmation from our rep that the TSX re-design will be for the 2009 model year. AWD is definite and so is the turbo (not sure if that will only be on Type S or not). RSX will come back same time as TSX Coupe. I have also been told this release will happen earlier than Fall 08, and more along the lines of the original TSX release (Spring 08)
This will also coincide with the TL re-design (Fall 08) for 09 model year with AWD as definite and 3.5L and a mid-model re-design on the RL.
#80
EDIT: AWD definite, no confirmation on Turbo yet........
