Removing Rear Parking Light Bulb
Hello, does anyone know how to replace the rear parking light blub in the rear taillights? I noticed its similar to the rear turn signal and the rear brake light bulbs (detach harness, and then turn to remove bulb socket).
Found the harness which unclips, but wasn't sure you can turn it too to access the bulb. Thanks. http://i11.photobucket.com/albums/a1...l_lightjpg.png |
Quarter turn to remove it. I don't know about the side marker, but the brake lights are only intended to go back in one way (so that the filament is vertical).
