Redline
101 years of heartache...
Redline
Today while in the car with some friends I decide to put my car into M (5AT). I ALWAYS turn the music down in order to better adapt to the change in RPM so I don't go over 7,000. Well tonight my friend blasted the radio once, I made him turn it down. Again while driving, I made him turn it down. Now FYI I'm not an MT noob, but I feel I am not quite an expert, so I take the proper precautions at all times. Well he does it again while I'm in 1st and I feel that the car is around 6 when it really sounds like its at 7. I look at the tach and I see the car drop down to about 3-4 when I shift out of what my rear seat passenger said was 7200. It was not 7400 now that I think of it (along with the engine shut off, the tach didn't read that much into mid-7k. 7200 sounds just about right, in a car that redlines at 7100. Have I done too much? Many well-taught car guys I talk to say everything is ok as I caught it 200-300 rpm before 7400. I think I only went 100 over redline.
So the question stands, what are the consequences (I hope none), if any? Lesson learned, don't under estimate the engine and don't let your friends f' around with your radio when you feel comfortable driving without it when you want to. Any insight is very welcomed. BTW the car is driving normally, now that I think of it I didn't do too much, but I'm still quite worried. Thanks.
Originally Posted by pandimus
Thats what the rev limiter is for. So you dont screw up your engine.
Use all 3 Pedals at once
The rev limiter doesnt always save your engine...
Let's say you mis-shift in a manual, going from 3rd gear to 4th, but accidentally shift it into 2nd, the rev limiter has no use for you or your engine at that point...
You shouldn't worry about anything bad happening to your car, it didn't go that deep into redline...
Think about the people who do redline shifts, or shifts right before fuel cutoff
Anyway back on course, yeah thanks for the info. Now that I've calmed down a little I realized it wouldn't have been that bad, it isn't like Honda made it do-or-die. Besides the k24 engine has one of the fastest piston speeds in the world today (something like 10th fastest . I can pull that up if anyone is interested).
Yea...I would doubt it too, but you also have to consider if the person in the other car wants to run you and also how good of a driver/shifter they are...
No, granny shifters here...
just for whoever is interested from my source the K24A2 has the 9th fastest piston speed in the world, at 4615 ft./ min. The non-USDM S2000 has the fastest, 2nd Lamborghini Gallardo, 3rd is the Acura Integra-R. Kind of interesting.
Originally Posted by RMATIC09
Why is it bad to redline on accident once in a blue moon? Alot of ppl i know shift at redline all the time, their car is fine?
Let me say that I've shifted in that area many times before, and nothing negative has resulted from it, well at least from my point of view, nothing has changed...
interesting. well we are the late night bunch, well see what the sensible ones have to say in the morning/afternoon (j/k). thanks for the input.
Master Graphic Artist
I take it to redline every now and then and have no problems at all... Once I misshifted from 5th to 2nd, good thiung I clutched right before the tac hit 5400. I raced a couple guys on their bikes today... We all know who won that one
pull it up
Registered AssHat
how do you go from 5th to 2nd?
(5AT)
u said it right there, i dont think theres anything in SS mode that u can to do break the engine, it wont let u downshift if ull blow it up, itll bounce off the redline if u forget to shift and itll downshift for you if u forget to downshift when ure slowing down.
its almost bullet proof, well user proof i guess we could say
Originally Posted by iamhomin
100rpm over 7k? Not a big deal.
this next post im going to put on has the fastest piston speed engines. I think i found it here after someone got into an argument but i have it saved on word.
Fastest Engine Piston Speeds
Here are the Top 28...
1. Honda S2000:
Engine Code: F20C1
Bore/Stroke: 3.43" X 3.31"
Redline: 9000rpm
Piston Speed: 4965 Ft/min
2. Lamborghini Gallardo
Engine Code: N/A
Bore/Stroke: 3.25" X 3.65"
Redline: 8000rpm
Piston Speed: 4866.67 Ft/min
3. Acura Integra Type R
Engine Code: B18C5
Bore/Stroke: 3.19" X 3.43"
Redline: 8400rpm
Piston Speed: 4802 Ft/min
4. BMW M3 (Germany)
Engine Code: M54 (?)
Bore/Stroke: 3.43" X 3.58"
Redline: 8000rpm
Piston Speed: 4773.33 Ft/min
5. Honda S2000 2004
Engine Code: F22C
Bore/Stroke: 3.43" X 3.57"
Redline: 8000rpm
Piston Speed: 4760 Ft/min
6. Honda Integra Type R (JDM)
Engine Code: K20A
Bore/Stroke: 3.39" X 3.39"
Redline: 8400rpm
Piston Speed: 4746 Ft/min
7. Acura Integra GSR 2001
Engine Code: B18C
Redline: 8200rpm
Piston Speed: 4687.67 Ft/min
8. Saleen S7
Engine Code: N/A
Bore/Stroke: 4.13" X 4.00"
Redline: 7000rpm
Piston Speed: 4666.67 Ft/min
9. Acura TSX
Engine Code: K24A2
Bore/Stroke: 3.43" X 3.90"
Redline: 7100rpm
Piston Speed: 4615 Ft/min
10. Suzuki Hayabusa Sport Prototype
Engine Code: W701
Bore/Stroke: 3.19" X 2.48"
Redline: 11000rpm
Piston Speed: 4546.67 Ft/min
11. Honda Civic Type R
Engine Code: B16B
Bore/Stroke: 3.19" X 3.03"
Redline: 9000rpm
Piston Speed: 4545 Ft/min
12. Toyota Celica GTS / Matrix XRS 2001
Engine Code: 2ZZ-GE
Bore/Stroke: 3.23" X 3.35"
Redline: 8100rpm
Piston Speed: 4522.5 Ft/min
13. Honda Prelude Type S (JDM)
Engine Code: H22A
Redline: 7500rpm
Piston Speed: 4462.5 Ft/min
14. Acura RSX Type S
Engine Code: K20A2
Bore/Stroke: 3.38" X 3.38"
Redline: 7900rpm
Piston Speed: 4450.33 Ft/min
15. Ferrari 360 Modena (incl. Challenge, Stradale, etc)
Engine Code: N/A
Bore/Stroke: 3.35" X 3.11"
Redline: 8500rpm
Piston Speed: 4405.83 Ft/min
16. Lamborghini Murcielago
Engine Code: N/A
Bore/Stroke: 3.43" X 3.42"
Redline: 7600rpm
Piston Speed: 4332 Ft/min
17. McLaren F1
Engine Code: N/A (BMW V12)
Bore/Stroke: 3.39" X 3.43"
Redline: 7500rpm
Piston Speed: 4287.5 Ft/min
18. Renault Clio 2.0 RS 2003
Engine Code: F4R
Bore/Stroke: 3.26" X 3.66"
Redline: 7000rpm
Piston Speed: 4270 Ft/min
19. Porsche 911 GT3 RS 2004
Engine Code: N/A
Bore/Stroke: 3.94" X 3.01"
Redline: 8500rpm
Piston Speed: 4264.17 Ft/min
20. Pagani Zonda C12S
Engine Code: M120 7.3 AMG
Bore/Stroke: 3.6" X 3.64"
Redline: 7000rpm
Piston Speed: 4246.67 Ft/min
21. Peugeot 206RC 2004
Engine Code: EW10 J4 S
Bore/Stroke: 3.35" X 3.46"
Redline: 7300rpm
Piston Speed: 4209.67 Ft/min
22. Porsche Carrera GT
Engine Code: N/A
Bore/Stroke: 3.86" X 2.99"
Redline: 8400rpm
Piston Speed: 4186 Ft/min
23. Acura NSX-T
Engine Code: C32B
Bore/Stroke: 3.66" X 3.07"
Redline: 8000rpm
Piston Speed: 4093.33 Ft/min
24. BMW M5 2002
Engine Code: S62
Bore/Stroke: 3.70" X 3.50"
Redline: 7000rpm
Piston Speed: 4083.33 Ft/min
25. BMW M5 E60
Engine Code: S65 (?)
Bore/Stroke: 3.62" X 2.96"
Redline: 8250rpm
Piston Speed: 4070 Ft/min
26. Nissan Primera W20V
Engine Code: N/A
Redline: 7200rpm
Piston Speed: 4068 Ft/min
27. Ferrari Enzo
Engine Code: F140
Redline: 8000rpm
Piston Speed: 3946.67 Ft/min
28. Ferrari 575 Maranello
Engine Code: 650 V21
Bore/Stroke: 3.50" X 3.03"
Redline: 7750rpm
Piston Speed: 3913.75 Ft/min
1. Honda S2000:
Engine Code: F20C1
Redline: 9000rpm
Engine Code: N/A
Redline: 8000rpm
Engine Code: B18C5
Redline: 8400rpm
4. BMW M3 (Germany)
Redline: 8000rpm
5. Honda S2000 2004
Engine Code: F22C
Redline: 8000rpm
Engine Code: K20A
Redline: 8400rpm
Engine Code: B18C
Redline: 8200rpm
8. Saleen S7
Engine Code: N/A
Redline: 7000rpm
9. Acura TSX
Engine Code: K24A2
Redline: 7100rpm
Engine Code: W701
Redline: 11000rpm
Engine Code: B16B
Redline: 9000rpm
Engine Code: 2ZZ-GE
Redline: 8100rpm
Engine Code: H22A
Redline: 7500rpm
Engine Code: K20A2
Redline: 7900rpm
Engine Code: N/A
Redline: 8500rpm
Engine Code: N/A
Redline: 7600rpm
17. McLaren F1
Redline: 7500rpm
Engine Code: F4R
Redline: 7000rpm
Engine Code: N/A
Redline: 8500rpm
Redline: 7000rpm
Redline: 7300rpm
Engine Code: N/A
Redline: 8400rpm
23. Acura NSX-T
Engine Code: C32B
Redline: 8000rpm
24. BMW M5 2002
Engine Code: S62
Redline: 7000rpm
25. BMW M5 E60
Redline: 8250rpm
Engine Code: N/A
Redline: 7200rpm
27. Ferrari Enzo
Engine Code: F140
Redline: 8000rpm
Redline: 7750rpm
That is the beauty of V-Tech. With an ordinary engine, redlining it often would hurt, but with V-tech, you can redline it and the wear is significantly reduced.
Moderator Alumnus
Originally Posted by LUV2REV
Since when did the Civic Type R gain a 9000 RPM redline ? I thought it was more along the K20A's.
Needless to say, the engine never made it here...
No need to worry about hitting redline or even going over it. You drive an auto it is impossible to blow that engine up, short of a failure of the auto trannie or not putting oil in your car. By design you cannot downshift to too low of a gear, the trannies computer wont allow the shift to happen. But for those of you that use your left foot while driving, over-revving is an issue. It is very easy to put the shifter in the wrong gear, so becareful. A new K24 engine would be a very costly mistake to have to fix.
vpasla1
09-17-2016 07:24 PM
D-Rob
62
01-05-2016 11:44 AM
EvilVirus
12-10-2015 07:38 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
