Rebadging the "Acura" and "TSX" back
TSX
I took it off for more of a cleaner finish when I first bought the car but I'm looking to put them back on.
Any suggestions on which double sided tape I should use? It looks like from the one that came from factory, it feels like a felt type of double sided tape.
Any suggestions would be appreciated. Thank you!
TSX
I got the double side 3M tape but this is going to be a bit tricky.
Did you guys use an exacto knife to tape it down first then use knifing out the empty spaces?
or
Did you cut a couple pieces for the A, then for the C, U and so forth?
or
El Cunado
I wouldn't use a knife against the trunk lid. See if you can place it down on a flat piece of wood/stone/metal that you don't mind cutting against.
I haven't re-badged my car but I remember the letters having their own adhesive behind them when I removed the badges.
TSX
still figuring it out. I might just do it piece by piece.
Let me help you!
I looked at my emblems a couple of days ago. If I remember correctly, the tape behind the letters were in segments (ie: the letter A might have had 3 small strips instead of an A-shaped piece of tape). I guess you'll just need to figure out how to handle the curves.
rockyboy
08-04-2024 10:35 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
