Rear Deck Speaker suggestion
Old Oct 20, 2005 | 12:01 PM
  #41
CJams's Avatar
Guinea Pig
Originally Posted by bullyx2
By the way, nice icon and line under it. Us Bucs fans REALLY miss #87.
Us Bucs fans up here in WA are very happy to have him. I had my #19 Jo Jo jersey and he switched to #83 after preseason so I had to buy another Jo Jo jersey. Rockin #19 as we speak! These fools don't realize how valuable he was in our playoff run for the Superbowl down there. Chucky used him as a secret weapon. We also got Darby on our D. They call him chuck instead of Chartric though. I like Chartric better. 2 sets of season tix at Qwest ran me $454 for both without a deposit. You can't get 1 ticket at Ray J for that.
Sorry for the
About the 8's, the only practicle way to mount them is using some type of non wooden adapter. Like fiberglass. I tried a couple of times. Would love to see someone do it if I don't get to it first. Good luck! I luv 8's!
Old Oct 20, 2005 | 12:11 PM
  #42
bullyx2's Avatar
'05 TSX CG W/NAV
My memory is awful, was thinking he was 87 here, but was 83. Sucked to see him leave. Could definately use him back.
That trunk mod looks farly simple, might do it in the coming weeks then look into the 8's idea. I'll keep you posted.
Old Oct 20, 2005 | 12:15 PM
  #43
CJams's Avatar
Guinea Pig
I got it backwards as well....he's #87 here....was use to #83 down there.
If all goes well we will see the bucs vs the hawks for the NFC. I would be torn
Old Oct 20, 2005 | 12:21 PM
  #44
peter_bigblock's Avatar
C'mon, man! Row yer own.
Originally Posted by CJams
. . . I replaced mine with JBLs and they sound great. Now they are amp'd by an alpine and are full range instead of just the lower freqs . . .
How do you like the full-range 6x9's vs. the stock bass-freq only setup? I don't care for the stock setup personally and have considered doing the same thing.
Old Oct 20, 2005 | 01:13 PM
  #45
CJams's Avatar
Guinea Pig
It seems as if I lost the real bass part of the 6x9's when I went full range. I thought it would keep the same bass and just add the extra highs, but it didn't seem to work out like that. No big loss since I have subs now. But as far as the full range 6x9's go, I love them. Everything sounds so good. Very happy with all the speakers I put in.
I still have 1 issue left, and thats unfcuking my rca conversion setup. I have found that there are more issues than just noise on those lines. Theres actual audio signal bleed through. I have my subs set up on the rear channels and if I fade all the way to the front and turn all the bass down you can still hear the subs. You shouldn't be able to. I have just been too lazy to un-butcher my rca's and replace my OEM amp. Then I am going to connect LOC's to the 4 door speaker outputs to send the signal to the amps. That should eliminate the noise and give me proper fade and balance functions.
Old Oct 20, 2005 | 03:36 PM
  #46
waTSX's Avatar
Have camera, will travel
Originally Posted by vitocorleone
The rear 6x9s are used for bass... I did what elduderino did, and replaced them with MB Quart References and left the tweets off. I also replaced the fronts with MBQ Refs and powered all the new speakers with a ~50w RMS amp. The rear door speakers were left wired to the stock amp, and everything was hooked up so I could still fade front to back even though the back has 2 different amps essentially.
While it's no 10"+ subwoofer, I have had people ask me what kind of sub I have and I get to say "none!".
(PS - we only have one car: the TSX, and need the trunk... too hard to manage putting a stroller in the trunk with a big ass sub in the way)
Vito, if you don't mind, which amp did you go with and where did you install it? How much did your setup cost?
I think just adding amp alone would be a big improvement for the TSX.
Old Oct 20, 2005 | 04:32 PM
  #47
MichaelkTSX's Avatar
05' NHB TSX
http://www.shinzu.com/tsx/images/repair/tsxaudio2.jpg
^^^^^if you can blow it up you might be able to read the wire colors^^^^
Couldn't find it very fast, but I know I saw the wire colors somewhere in the A/V DIY thread for the TSX.
THANK YOU!
I did have the polarity crossed and thats why my typeS speakers sounded like crap. I'm such as idiot.
THANK YOU!
Old Oct 20, 2005 | 04:47 PM
  #48
05' NHB TSX
I spend the whole day yesterday trying out different speakers. Here is my review, based on my person perference.
I tried the kenwood KFC-6949S which were the cheapest speakers. They produce about the same or lower quality sound as the stock Pioneer but they seem to be built better. REJECTED
Next up is the Kicker KS69. As far as bass, these baby felt the best to my ear and arse. HOWEVER, they do not fit the TSX, the screw holes do not line up with the holes on the speakers. I was only able to put two of the four screws back in. You can drill the holes on the speakers to make it bigger but I didn't want to mess with that. Also the plastic ring is glue to the top of the speakers so you have to pry it off with a flat head else you won't be able to close the stock grill. That or grine the stock grill bottom. RETURNED
Tried the MTX TDX6902.....not as good as the TypeS plus the holes on the speakers are round instead of oval so they don't really fit unless you're drill it bigger. RETURNED
So here I am, back with the Alpine Type-S which are the winners for me. Bass is slightly below the Kickers. Everything else is right,these do sound better then stock (when I got the polarity right geez). They slide right in and screw up nicely. Fits inside the stock grill. IMPRESSIVE, perfect for the TSX rear deck.
I want to thank everyone esp CJams for finding me the correct wires. Pretty soon I'll probably upgrade the front door speakers too. Great forum!!!
Old Oct 20, 2005 | 06:10 PM
  #49
vitocorleone's Avatar
I didn't want to mess with the passenger seat in order to install an amp beneath it (it needs to be raised a little... elduderino did this himself), so I wanted one custom mounted in the trunk. As such, I also wanted it to have a fan, but didn't want to spend a fortune.... I think in retrospect I'd have purchased an even nicer amp, but I went with a Kenwood amp that had a fan (I don't remember the model, but I think it's a 40 or 50 x4 RMS amp). The installer threw in a lightly used 2 channel Audiocontrol crossover to fine tune the 6x9's (used the amp's built in crossovers for the front speakers).
The amp was custom installed on its side against the rear right panel in the trunk behind the wheel on a vertical steel mount with a custom cover and fan vent.
I spent the money most spend on the nav unit and spent it on 4 speakers (all MBQ Reference), an amp and professional installation (using the stock head unit, which I had to have replaced because it was skipping on cds). Threw in some additional insulation in the doors and I paid ~$2,500 at Magnolia A/V in Bellevue. The lead installer did the work, which took longer, but the work is quality - his nickname is Woody.
Old Oct 21, 2005 | 03:12 PM
  #50
raltsx1's Avatar
I finally hooked my amp up to the Alpine 6x9s. It gives them enough power to produce nice clean bass without drowning out the factory speakers. If the speakers alone aren't playing loud enough with the factory amp I would recomend adding a small one. This is what I used http://mtx.com/caraudio/products/amp...hunder251D.cfm
Old Oct 21, 2005 | 03:30 PM
  #51
kmonster's Avatar
uh, didn't even know the TSX had pioneer stock speakers....good to know!
Old Oct 21, 2005 | 04:10 PM
  #52
raltsx1's Avatar
Wrong link http://mtx.com/caraudio/products/amp...Thunder202.cfm
Old Oct 21, 2005 | 06:29 PM
  #53
jkozlow3's Avatar
raltsx1,
So with that amp, you don't need to run power from the battery?
How did you install it?
Did you splice into the speaker inputs going into the factory amp?
Did you need to run new speaker wire to the new speakers?
Where did you install it?
I'd be VERY interested in an amp that could basically just replace the factory amp in the same location with a MINIMAL amount of work (allowing me to upgrade to some decent speakers). I doubt this exists though. But if it does, please share!!
Old Oct 22, 2005 | 09:12 AM
  #54
raltsx1's Avatar
You still need to run a power lead which is pretty easy, but you don't need to run a remote turn-on wire. The amp automatically comes on when it senses a signal. Seems to work fine.
Old Oct 22, 2005 | 01:01 PM
  #55
xenonhid's Avatar
CGP Ebony
Originally Posted by peter_bigblock
Elduderino (an AZ vendor) sells a set of six speakers that I gather (from this forum) is a good replacement for the factory setup for around $400. My guess -- I don't have his kit -- is this is as good as you'll do for the money.
Beyond that, you're out of my league if you're in a higher price range than that. You might also consider a sub if you're looking for that thump. Just as an aside, as project studio recording nut, I can tell you that thump (or, really, thwack) you feel from a kick drum is not bass in the subwoofer sense. It's about 250Hz-500Hz. It's more the result of a well-engineered album than a subwoofer.
Good luck!
Cool, Do you produce/edit your own music? I would like to hear some samples?
Old Oct 25, 2005 | 10:27 AM
  #56
jlukja's Avatar
Nice review. Very helpful to readers trying to decide.
Old Oct 25, 2005 | 11:37 AM
  #57
CJams's Avatar
Guinea Pig
MichaelkTSX- YW!!!
Good review! A few people have gone with the pines on the board! And yes! This forum does kick ass! It helped save me lots of time money and energy while building my ride! I think the collective minds here may know as much or more than the guys that built the car
hmmmmm....Maybe we should be involved with the design of the 07?
Old Oct 26, 2005 | 02:45 PM
  #58
PixelHarmony's Avatar
Master Graphic Artist
Originally Posted by jlukja
Those are rated 80W nominal / 300W peak. No problem with the OEM amp driving them?
They were actually not as responsive as stock speakers, but at higher loads they do play louder and clearer. I'm just waiting to get my 4 channel amp so I can paly them even louder.
Old Oct 26, 2005 | 04:59 PM
  #59
jlukja's Avatar
There are some Diamond Audio M391i 6X9 Speakers for sale in Black Market. They look pretty decent.
Feb 25, 2020 09:57 AM
Dunnik
Sep 15, 2015 11:52 PM
Pegon95
Sep 15, 2015 01:54 PM
Joe Tschida
Sep 13, 2015 12:22 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
