Radio install help
Radio install help
Ok guys gonna try and tackle a new project on my tsx trying to install a double din were the storage space is at I just need the double din for navi not for music so basically I just need to get a ground and a power it's an 08 tsx if that helps thanks
Some people say you can tap off the power going to the stock radio. I just ran a new wire with a fuse from the battery to the headunit and tapped off the cig lighter for the ignition. For the ground you can connect to a nut anywhere behind the console.
BoricuaTL
04-08-2016 01:08 PM
