radiator fluid
i let dealer filled up during services/recall.
or Honda Coolant. Honda's formula is different to others (GM) i think you can filled with Prestone's new one that claim to be compatible with all make. but if you want to keep retain extend drain period on coolant; the use Honda coolant only. it cost about $11-12 at dealer, pre-mix. if it's only a little low, i would not bother, wait til next sevices and let them top it off.
mine got a bit low too, i check the little reserve tank. i hope it's not leaking, but engine oil looks good so i don't know... vapourized???? ... Honda's coolant contain no silicate, and load of phosphate. mixing coolant reduce it's full performance.
Just dial 1911
1 Post
Reserve tank is not a reserve tank at all. Its a spill over incase the coolant gets overheated. So, instead of blasting the cap off your raidiator, some of the coolant will spill into it. Its not used to suck up new coolant, so if your filling this up with new coolant, dont.
Just dial 1911
1 Post
thanks
so rad does not suck coolant from it? i thought the coolant spill into it when got then when engine cold it suck some of it back. maybe i am wrong, help
In answer to the original question, coolant contains water, which evaporates when exposed to the atmosphere, so the level in the tank will tend to drop over time. It's such a small amount that you should be fine topping it up with water, but the proper thing to do is use the recommended coolant (in this case Honda type 2).
wait, i just checked it again. gogozy and poltergeist are right, i think it does work like a reserve thanks.
in the morning, it was at min, now its about a inch above the min level. thanks for the help guys.
SidhuSaaB
05-30-2020 12:40 AM
