question about NAVI DVD unit
Old Jul 17, 2005 | 04:47 PM
glassjaw's Avatar
can you tap into the back wires of the NAVI dvd/pc card unit thats in the trunk? specifically i need the battery wire, acc, and ground
oh and which color would be the battery and acc
Old Jul 17, 2005 | 05:54 PM
CJams's Avatar
Guinea Pig
Connector C on the DVD box has ACC and GND. It's an 8 pin Black/White connector. pin 2 should be yel/red (acc), 4 Blk (Gnd). I don't know if I would mess with that though!
Old Jul 17, 2005 | 07:19 PM
glassjaw's Avatar
ok thanks! i wasn't going to splice through it, i was going to use my wire taps. would you still recommend not to touch it?
Old Jul 17, 2005 | 08:48 PM
Alin10123's Avatar
I wouldn't mess with that either. If anything were to happen to your navi whether your fault or not, you know for a fact that the dealer is going to blame the wires that you spliced into for the problem.
What exactly are you trying to hook up? If the device draws a lot of power, it may mess up the navi, or could even blow the fuse that's at the beginning of the line.
95legend6speed
Sep 21, 2015 06:40 PM
datadr
Sep 12, 2015 09:12 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
Gianni Formica
Sep 7, 2015 08:28 PM
yahelou
Sep 6, 2015 09:12 PM
