parts identification
Anyone link me up the part number for the oil fill flap, mine was missing from my undertray when I bought it.
I have various self tapping clips that are used for the under tray, however there are two which are slightly different. The two I am talking about are the ones located on each side of the front wheel well area. They assist in holding the undertray up.
Thanks,.
Thanks,.
Took a little leg work (computer actually), but here you go:
Oil drain lid: 74114-SEA-000
Bolt: 90111-SM4-003
Bolt clip: 90305-SM4-000
If you're missing the two rear most bolts for the cover itself, they're the same as the bolt part number listed above, and I'm pretty sure they don't use a clip. You're welcome.
Bolt: 90111-SM4-003
Bolt: 90111-SM4-003
Bolt: 90111-SM4-003
Bolt: 90111-SM4-003
Bolt: 90111-SM4-003
The undertray clip I was referring to are the only two that are mounted vertically, one in either wheel well area.
The three part numbers are all for the flap you're missing (the flap itself, the clip and bolt that are used to hold it in place). I'm not sure which other clips you're referring to as the diagram I have doesn't show any clips of which there are only two required. I'll check it again when I have more time. Of course an Acura dealer could help you out too.
Bolt: 90111-SM4-003
Bolt: 90111-SM4-003
handsom-hustla
11-13-2015 05:04 PM
