Oil Catch Can
A closed system recycles crankcase blowby, oil vapor to the combustion camber. If you place a catch can in between the PCV valve and the intake manifold, it's still a closed system.
An open system doesn't recycle crankcase blowby, but allows venting to the atmosphere instead. If you see a catch can with a filter on top, it's an open system. An open system is usually found on FI setup engines as the PCV system is not operational during boost (the PCV valve requires vacuum to operate).
Because Of You
Got it. Thanks. But what is FI?
Received 3,858 Likes
so can i use a greddy catch can then.
IBankMouse
06-13-2020 12:53 PM
