Oil Analysis results show higher than expected iron, lead
in the 24th and a half...
Blackstone just got my results of a 25,000 oil change analysis. Interval was right at 5000 miles, but I showed possible high wear with:
Iron at 21 vs. 8 average, lead 8 vs. 1, high calcium, and slightly elevated phosphorus and zinc.
So, they indicated a possible wear issue with the cyclinders and bearings. My engine is buring about .2-.4 quarts between 5000 mile changes with Mobil 1. I'm self changing, so I know it's done right. Anyone had similar results? The comparison is vs. Acura 2.4's and I'm wondering if perhaps we expect higher wear on the K24A2 since it is a somewhat hard running engine and if perhaps there are other versions of the 2.4 that are a little less stressed and might drop the averages.
you are complaining about .2-.4 quarts???? I burn 1 qt in 3k miles and I have 77k miles on my 04 6MT. Burning oil is typical of Honda motors.... why, I don't know but you need to check with Acura first on what the burn rate is that would be of concern. I know Nissan says until you burn 1.5 quarts in 3k, they don't want to see the car.
For comparison purposes check out this thread: https://acurazine.com/forums/showthread.php?t=22090. I posted my oil analyses (2 of them) from Blackstone as did some others.
No, I'm not complaining about the oil burn, I think it's fine. the iron/lead does worry me a bit.
Originally Posted by DuckDodgers
Thanks, I searched but used a bad conditional. I knew there was a thread out there, shrug.
