New 1st gen 05 TSX Owner
Do's & Dont's
Coppin a 05 Tsx with 175,000 miles on it and I was just looking for any advice on what I should do first with that bad boy. (Mod and maintenance wise) help a young boy out, first car and tryna be out here driving smoov & in style dig me.. hearddddd all seriousness doe.. comment some real og advice and recommendations my nigga |
Change ATF w/ Honda ATF is a good place to start.
good luck |
Howcome?
Unless you know that a change occurred w/I a reasonable time frame (2 yrs30k miles) it should be changed. Most expensive component of your car deserves premium treatment.
good luck |
I'm with TexasHonda with changing ATF along with all other fluids if you don't have a record of the maint (anti-freeze, power steering, brake, ATF). You might include serpentine belt, cabin air filter, engine air filter, and spark plugs if you are not 100% sure when those were changed. Might even do an alignment to make sure you don't have any worn suspension parts like control arm or need a camber adjustment kit.
