Need additional Help with NAV System
5th Gear
I posted back about the window tint causing the NAV system not to work. I had the tint taken off the rear window and Acura once again swapped it with another NAV system. However it still does not work right. I was just wondering if anyone else has experienced this or has any suggestions. The same tint is still on the side windows could that still cause a problem?
Originally Posted by Edoco
I have the same problem... Acrua said that it was the tint. My navi is off by 2-5 miles sometimes... How is that? Isn't the antenna outside above the rear window?
That's the XM radio antenna, the navi antenna is somewhere else ( I forgot where exactly) Someone else wil let us know I'm sure
Summer is Coming
Originally Posted by yadfgp
That's the XM radio antenna, the navi antenna is somewhere else ( I forgot where exactly) Someone else wil let us know I'm sure ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
FYI... in the 06 Civic they put the GPS antenna under the front dash. Maybe a little smarter.
Originally Posted by Rocket_man
The GPS antenna is under the rear shelf in the back window. That is why metallic tint in the rear window can effect reception. You may also get multi-path from reflections inside the car. The antenna on top of the car is the XM antenna.
Summer is Coming
Well they removed the tint and the navi is back online. I'm happy. The tint was installed by the previous owner and I always thought it was a little too dark. Any recommendations for tint that doesn't affect the navi reception? I'm looking for manufactor names.
Madico Charcool. I've got that on my TSX and the color is perfect. Not too dark, slight reflective quality, perfect. Plus it doesn't effect navi or AM radio at all.
navtool.com
31
11-16-2015 08:30 PM
