MY Rotors are Definetly Warped.
#41
Originally posted by unsure
...dont 4get, brakes, like the engine, MUST be broken in properly, if not their performance will be noticeably reduced and may result in consequent problems such as warping
#43
TSX's are known for weak brakes and rotors, why they think that a cars breaking system isn't as important as it's handling I have no idea
As far as going in nuetral coming to a stop, that is the preferred method because it's always easier to replace pads than replace a clutch!
For a car to be doing that already in those miles, no matter if semi agressive or not, it is not normal, however I would look into upgrading. It's funny b/c with Bimmer's soft pads, and as aggressive as I drive at times, I have only replaced pads once with 60k miles.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
#44
Re: Re: Re: Re: MY Rotors are Definetly Warped.
Originally posted by chrisalberts
Disagree. Sometimes due to heat, pads can leave chunks of pad on the rotors that have a similar symptom to warped rotors. Sometimes you can melt it back off again with some brisk stopping.
What's your definition of glazing then?
C.
C.
#45
Originally posted by Saintor
This is what irritates me most with Honda. Weak brakes! They should really consider taking their brake designs from Toyota. On my Accord, I have changed pads at 77000km and at pads mid-life at 110000km, the rotors are warped and there are vibrations when braking from 80km/h.
If you are on warranty, don't accept that they only resurface the rotors.
#46
Originally posted by domn
....But are'nt TSX brakes from the RSX? and I've heard no reports like this from any RSX owners.
#47
I didn't wade through the entire thread, but in my previous experience with Honda and Acura cars the rotors are almost guaranteed to warp after they are turned.
I'm not sure why this is, but I gave up turning them and just replaced them after 60K miles in my Integra. I'd replace the pads as needed, but insisted that the rotors not be turned when this was done. They were still unwarped when I sold the car with 197K miles.
Also, all brakes need careful break-in to properly seat the pads into the rotors. You should avoid hard braking for at least 200 miles in a new car. A hard stop prior to proper seating of the pads can also lead to premature rotor warping.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
