my new modded TSX KEY
#161
i want to ride my bicycle
Score!
So i was picking up some Honda coolant to instal my heatshield gasket at the local honda dealership (they are a lot closer than the acura one) and i stopped by the services desk and asked how much to program the transponder chip in my key with my car (i told them i already had everything cut and it just needed to be programmed) and the said FREE! so he grabbed his HDS tablet and in 5 min i had a new Accord key/fob that was programmed to my car
So to review:
Accord key/fob: $35
TSX blank key: $2 (from Lowes Hardware Store)
Programming Accord key to TSX: $0
$37 plus an hour or so to make the key not too shabby. I am glad i didnt end up having to cut up my tsx key (not that it really matters too much this is a sweet mod, but I now have 3 keys + the valet key )
So to review:
Accord key/fob: $35
#162
Just dial 1911
1 Post
So to review:
Accord key/fob: $35
So to review:
Accord key/fob: $35
#164
She said: it's GINORMOUS!
virus - that's great news!!
i just spent two hours and finished mine (exactly like JTso's pics), def saved me from dremelling my valet key (dremelled a copy instead)
now i need to get some exproxy to seal, then convince the service dept to program my key. thanks everyone for the info, this mod rocks!
#165
Hey guys,
Im looking to do this as well. What all do I need? How would you shave down the master copy key so it would fit? And what would I need the epoxy for?
Tuan
Tuan
#166
Originally Posted by tuan209
Hey guys,
Tuan
Tuan
#167
Originally Posted by moda_way
Do a search on my DIY and use some of the suggestions from this thread.
-a dremel or craftsman RTX with a cutting disc, sanding tip, engraving tip, cutting tip, drill tip (all comes w/the dremel kit).
-an extra copy of the master key (from locksmith)
-an accord key from dealer
-safety glasses (very important!)
1. follow directions from moda's posts to take apart the accord key, then start shaving off the plastic edges holding that key.
2. once you remove the accord key, lay it over the copy'd key and trace out the edges of where you need to cut with the dremel cutting disc.
3. after cutting, slowly sand down the edges using the different tips until it's a perfect match from jtso's pics.
4. finally, trace out and drill the hole for the accord screw
5. apply exproxy and let it cure. jtso recommends JB Weld from any hardware store...TADA!!
#169
well i am right where JTso is at.
I went and had a key cut at Lowes (hardware store) for about $2, but i have been calling locksmiths and they are wanting from $90 - $120 to program the car with the the new transponder chip. I am going to try calling again tomorrow.
The SDD programmer seems to be about $5000, but I think the process is rather simple for the locksmith. I will keep everyone posted.
#171
Originally Posted by kaliraver69
What type of key did you get for $2? Also basically what you need is the USDM Accord FOb a blank $2 key and get it programmed?
yeah you will need Accord FOB: ~$35; blank key: $2; and then mod them together and get the transponder programmed to the car.
#172
Has anyone tried just having the original key on the key ring with their new key? Or taping it to their ECU?
My understanding is it is just an RF chip so it doesn't really have to be taken out of the original key as long as it is present.
#176
#177
not to sound like a noob but will any blank key work for this mod? Am just wondering since I don't want to repoxy stuff over & over.
#179
Missin my TSX =(
WELL.... just flew home from skool and check the mail expecting my key to b in from modaway and bamm .... its there... ripped it up and looked at it with excitement (like a little boy) and programmed it (15 seconds) and it worked....
just want to say thanx to modaway for prompt, beautiful work... looks great, works great, feels great.... best mod indeed.... thanks again dude...
all u ppl should get this and go to modaway hahahahhaha
a before n after pic (sorta combined)
#181
ABP TSX
DAMN this KEY is becoming an ALBATROSS
Thanks guys for writing some feedback. Again, if anyone is interested, just PM me for the info.
Ok, I had had problems getting someone to cut my key for the mod, but I was able to get that solved. Now I am having a damn time getting the Immobilizer programmed. I stopped by a Honda Dealer this morning. They entered my VIN to get some pass code and told me that it was not in their system so they could not program the key. I said you should be able to and that went nowhere. Even after explaining, they still said Honda key and Acura car will not work. I cranked the car over in Service and still they said “we cannot do it.” Reluctantly I left the dealer.
I called Acura. They said they might be able to clone the key at the Parts Counter for $25, but it had to be an OEM key. However, the Service Advisor said he doubted that would work because the “cut key” was not OEM even though the Fob is genuine Honda including the Immobilizer. He said a tech would need to more than likely hook up the “programmer” to my car. He said since this was not an OEM key or in his words a hacked up OEM key, that the hook up would be $90 (1 hour labor) alone and then REFUSED to estimate me a price on getting the key programmed. I explained this WAS on OEM key but he said Honda and Acura are completely different on the Immobilizer. WTF WTF WTF
After I pressured him, he said the minimum would be $180 or 2 hours of labor. I really did not want to hack up one of my original keys but damn ….
I know this process HAS to be simple at the dealer because several of you already have completed the mod.
Can anyone tell me exactly what I need to tell these Service People I need done in their terms? Telling them that I need the Immobilizer programmed on a key obviously does not work.
Can this key be cloned as the Acura guy mentioned at the Parts Counter without the Service Hassle?
I go in the Honda Dealer in dress clothes, and get treated like one of these
#184
Bye TSX, hello domestic?
any suggestions for getting the screw out of the back of the key? moda_way's instructions say to drill it out, but have others been able to uncrew it? i can't get enough pressure to break it loose, I feel like either the screw or my crappy mini screwdriver is going to strip
#186
Originally Posted by JTso
The screw tip has loctite on it. But I was able to use a #0 tip to remove the screw without any problems. I also tapped the replacement key and reuse the same screw to secure the keyfob.
#187
I've been successful in all the keys I've modded to get the screw out. It absolutely takes a #0. On my key, the first one I modded, I tried a #00 which did strip it out. Since then I've been able to get the screw out just fine.
#188
Originally Posted by xizor
sounds good, just from readng your instructions at the beginning of your thread you said you drilled it out. just wanted to double check that wasn't totally necessary
#189
I kAnt Spel guD
Originally Posted by Motohip
Never mind...the FCC is different on the CL...maybe I could swap the ICB, or TCB, or whatever it's called.
Oh well, at least the TSX gets the fancy new key...
#190
ABP TSX
I received my Key Mod from moda_way today. As expected, the work is pristine and perfect. If you do not have the time nor patience for this mod like me, I would suggest his service. You will not be disappointed.
I cannot wait to and the Acura Dealer this Friday for calling me a hacker when I get my headlight replaced later this week.
#191
Mmm.. Acura cake
But can you mod it into a watch?
http://www.akihabaranews.com/en/news_10323.html
On a more serious note, I hope moda_way is still offering this service when i get my '06 !
#192
Definitely!!
#193
I'm a llama :(
So, with trying to get it to work with a remote with a different FCC number, is that just a different frequency? Can you swap just one little part of it to get it to work?
#194
#196
I'm hoping I can like swap some chip or something and it'll work.
You still have to program the buttons on the key, but that takes like a minute. Instructions are in this thread.
You can't have the Accord key cut b/c it is a totally different key all together, so you either have to use a key you had cut by the hardware store (which means you need to have the chip in the Accord key programmed by your dealer) or use the TSX key and modify it to work inside the Accord key.
#198
No, not the chip in the key, the chip in the remote part. Since the FCC numbers are different, I though there might be a way to swap something.
My bad... there is no... chip... that I'm aware of in the remote. Eventhough the FCC numbers are different, they still operate the system. You can't really unchip the remote... besides, there aren't compatible from the fob to the Accord key as a swap... you have to merely program the TSX computer to accept it. Fairly simple to do.
#199
Brilliant idea to mod the key!!!!!
Two questions: 1) Why doesn't Acura offer a key like this?
2) Why doesn't Acura (or any other car maker) offer a remote transmitter that can be programmed for two cars? There could be a slider swtich on the side (for example position 1, TSX and position 2, NSX ) so that repeat customers of Acura have an incentive to stay loyal to the brand. I own two Acuras (2004 TSX and 2001 MDX) and it is a pain to have two remote transmitters on my key ring!!! This isn't rocket science!!!
#200
