My iPhone won't sync with my HFL
mrgold35
You can find the instructions to pair your phone from this site:
http://www.handsfreelink.com/?page=findaphone
I have the iPhone 3GS (wife) and Blackberry 8530 Curve (my phone on Sprint). I had a hard time keeping both phone paired to the TSX at the same time, they just didn't play nice together. I had to delete the iPhone and just stay with the Blackberry only. I still had problems with the Blackberry paring and staying paired with the TSX. The web link above said the 8530 Curve (Sprint) wasn't on the list as a compatible phone for the TSX.
We just recently switched to Verizon and I have the exact same 8530 curve and I had no problems staying paired with the new phone (Verizon 8530 Curve was on the list).
I check to ensure all old phone pairings are deleted from the TSX.
Chapter Leader (NorCal)
not sure if this helps but the 3g TL was and still is having issues with the iPhone pairing. The one solution that has worked for most is to do a hard reset on your iphone and power it back on. Once back on, go to settings and turn on Airplane mode. Then go back to your General settings and turn back on Bluetooth mode while Airplane mode is still on. Go through the pairing process. You should be successful. Note: You may still have to repeat this process ever so often. It's been reported that it loses the automatic pairing when you come back into your car and turn it back on. It started arising after a version update about 6 months ago. Good luck.
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
phillyguerrilla
09-26-2015 11:27 AM
