MOTHER of all potholes
Last night, driving home from the gym I drove over a pothole the size of Texas ... Man, it felt like I hit a deer.
Now I know our tires are sorta low profiled and the suspension is such that it can handle a little rough edges like potholes. Plus things always FEEL worse than they are.
My concern is that I effed up my alignment or something ... I mean, if I let go of the wheel, the CAR ALWAYS pulls to one side no matter what.
The car only has 600 miles on it ... How can I tell if I messed it up. It "seems" fine ...
Thanks in advance ...
Anthony
Anthony
Avenutolo, I'm sorry to hear that. Hopefully your suspension is fine. Did you notice from day one that when you take your hands off the wheel, it will pull to one side? It happens to me too since delivery. When I let go of the wheel, the wheel will slowly start turning left and the car will go left.. When I go pick up my license plates, I'm going to ask the dealer to check my alignment under warranty.
this what you hit?
Nah Sounds like ur just a little out of alighnment, no big deal, pot holes and other bumps can do this to ya, not really a problem
Almost any corner garage can check the alignment, but your dealership should do it for you while you wait. There are so many potholes and construction patches on city streets here I just get used to having the front end checked and realigned at the end of every winter season.
Other thing you might check is whether you lost any air from the tires; a massive one-sided pothole skirmish could have you driving with an unequal tire pressure and either be the solesource or a contributor to your "hook". I try to check my tire pressure about every two or three thousand miles, but it is the first thing I check if the car is "drifting". So far, with the TSX, I've had good luck.................
The car has only 600 miles but I'll check the pressure ... The salesman told me the pressure was soemthing weird like 29 in the front and 35 in the back or something ...
How do you guys do it??
Well here in Jersey where it snows every other week or so, the roads are fraught with potholes like little mines ... The one hit last night was HUGE, but most are average ... but the thing is they're EVERYWHERE ...
BTW ... why in the hell does Cali have potholes?? What are they from? Earthquakes?
6th Gear
I hit a bigass pothole here in Atlanta and it bent my f'ing rims. Dealer wants to charge me over a grand for 2 new wheels, camber, and to repair the rear suspension. What a rip. I have to see if my insurance will cover it.
Use all 3 Pedals at once
Hey man ... That's awful. Question, though. How did you know your rim was bent?? Was there an obvious change or shift in the way your car felt or could you merely see the damaged rim?? Just wondering if mine is bent.
6th Gear
Naugh, the car drives the same, but I can actually see the rear wheels are kicked out a bit at the bottom. Also, I assume the tires will wear faster and it'll be a bitch to align properly.
Cali potholes:
j/k only the last one is in Cali
ATCer
I say that in regards to this thread https://acurazine.com/forums/showthread.php?t=20393
I hit one three nights ago while driving home in the rain. Not the size of Texas but it was deep enough to put a bulge in my right front tire and damage the undercarriage (catalytic converter heat shield is loose and there is some cable hanging down after the housing broke off). My car tracks straight though and the tumored tire hasn't lost any pressure. My technician said if the car tracks straight on a flat road then my suspension is fine. I'm getting the car examined comprehensively next week. Supposedly I can file a claim against the city if the damages exceed a certain amount.
Damn ... that's truly awful. I once hit a pothole here in Jersey and effed up my whole undercarriage. This was on my first TL...
Technically, hitting a pothole is NOT covered by warranty. If they see that there is damage from an impact, they'll let you know that it's a Customer Pay item. If your aligment is tweaked from any damage, they're not going to cover it, being that it is NOT a manufacturer's defect. Hitting a pothole is not the manufacturer's fault.
I know this because (since you may not know) I know everything. j/k I used to work for AHMC for 4 years, including time as a service rep.
What Kurt says is absolutely correct; any road hazard damage is not covered by warranty, that is like asking Acura to replace your bumper because you backed into a loading dock.
