Modify your navigation system
#205
Originally Posted by iceman804
help with what?
#209
I would say ask a friend to borrow a cdrw burner, but i guess that be hard, if i live in orland i lend u my burner. I know someone in orlando, but i dont know if he will lend his burner to you. I would say go buy it, its cheap but dont know if u want to waste the money
#213
Im so miserable! My navi has been in the shop for 17 days!!! If i dont get it back from acura by wednesday, im stealing another tsx from their lot and messing with thier navi. My loaner is a non-nav. BTW, 6 speed rocks and i now hate auto. it's like being on the wrong side of a window in front of a candy store....
#214
#215
Very nice background. Do you have the psd, I wanted to add my name or something somewhere on the screen as well. Thanks.
in case you guys want something just a little bit different from the original.
#219
Something like this
#220
What are you guys using to make the bmp files?
This is what I did:
I used photoshop to open up one of the bmp files in this thread.
I cropped and resized a jpg file to 480x234
I did a "select all" and copy the jpg
did a paste to the bmp file.
This is where the problem starts, seems like after I do a paste to the bmp, I'd lose all the color info from the jpg, and it just shows up in black and white...
any pointers?
Thanks.
This is what I did:
any pointers?
Thanks.
#221
This is what I did:
any pointers?
Thanks.
This is what I did:
any pointers?
Thanks.
When you select all, go to new to open the blank sheet. Before clicking ok, select RGB near teh bottom. You are probably opening the new image in grey scale. Then paste. Should solve the problem
#223
bysin, is there any way that you can modify other stuff such as the way the Auido and/or climate controls look? Is there a way to make new skins for the that current software so that we can change the look of it? Can you add mpeg and mp3 functionality to it?
Also, can you post some links to documention on the SH-4 assembly language that you have found most helpful. Are there any detailed specification on what type of hardware is in the Acura TSX audio/climate/navi unit.
#226
well, it should still look okay. its hard to notice, its just off a little itty bit.
here is the file, ratio compensated
http://uploadhut.com/view.php/62231.psd
here is the file, uncompensated (you probably want to start from this)
http://uploadhut.com/view.php/62238.psd
hopefully i'm doing this right, following the ratio directions from earlier in this thread.
#229
Originally Posted by MoFocker
do i use the compensated or uncompensated one? i see how one is a little taller then the other...
#233
can we say wifi?
umm yeah i dont know how to work my roommates camera (hence flash) but im a better programmer than photographer :P
looks like i found a new project for my week off.. check out the acura tl recognizing the cisco aironet 340 series pcmcia card in the trunk
#234
i got it to work. i cant tell if it takes longer for the splash screen to show up after starting the car then it used too... seems its blank for 5 or 10 seconds rather then instantly showing up; or i could just be imagining things.
btw, if anyone messes up you dont have to disconnect the battery i dont think. just put the navi disc in, do the menu, cancel and map, hit version and hit load disc. it should just reload the original software from the dvd disc.
#236
well MoFocker i dont think ur imagining things i am getting a similar delay and i was told its becuase my back.BMP is larger that the orignal one but i checked it has the exact same properties as the orignal one and i am still getting a delay
