Metallic vs Pearl
Metallic vs Pearl
Found this old thread but I don't feel any of these guys clearly addressed the difference between the two.
http://www.acura-tsx.com/forums/show...lic+difference
Could anyone explain it to me?
They are not the same thing. Pearl paints used to use actual flakes of mother-of-pearl or crushed pearl to create a soft toned, shimmer effect. Nowadays, they use a synthetic compound with similar light refracting qualities as pearl, but costs a whole lot less. Metallic paint uses actual metal flake mixed in with the paint. This gives the paint a sharper glow and typically, you can see the metal flake in metallic paint if the sun is out and you look closely whereas you really can't see the pearl in "pearl" paints.
And to address the issue brought up in that thread of the automatic tranny being priced the same as the manual, that's actually a bonus. Technically, the base price is for the 6MT and the 5AT is a no-cost option so Acura's explanation is that they're doing AT buyers a huge favor by saving them money.
So basically, there should be no visual difference between the two if we assume similar light refraction/reflection indices. But if you consider the chemical inertness of mother of pearl, then wouldn't this type of paint retain its glossiness longer? That is, if real pearl is used. I imagine, as CGTSX2004 pointed, most compaines don't.
Wonder if there are any exotic car manufacturers using Platinum or Gold in their paints?
08_UA7_Gr33k
02-11-2016 02:17 PM
AcuraKidd
09-26-2015 04:10 PM
AmplifiedDetails
09-24-2015 02:55 PM
