Man does it sound better now!
#81
Use all 3 Pedals at once
Originally Posted by drigo
don't forget spacers depending on which speakers you go with...that would require drilling holes in your doors for mounting the spacers...just letting you guys know... also i would recommend the wire harness...that way if and when you decide to get rid of the car...it would be easier to swap back to the factory speakers..
As for the 6-1/2" door speakers...do all 4 doors need these mounting spacers? And where can I get these spacers? What are these spacers for?
I'm also looking to get the Infinity speakers all around
#82
Originally Posted by TSX 3Pedal
Are the rear 6x9's just direct drop-in replacements or do they need spacers too?
The 6x9s are a direct drop-in, no spacers required. The screw holes on standard 6x9 speakers should match up with the screw holes in the rear deck.
The OEM 6-1/2" door speakers have a plastic enclosure that snaps into holes in the door. Any aftermarket speaker will have screw holes for mounting so you will either need to drill holes in the door metal to match up with the speaker mounting holes or buy/make an adapter/spacer. The second reason for the spacer is that most aftermarket speakers are deeper than the OEM speakers (due to a larger magnet) so you need a spacer between the speaker and the door to make sure that the magent doesn't interfere with the window when open. Note the speakers that I installed had wooden spacers that allowed me to bolt them into existing holes on the doors and then affix the speakers to the spacers using the speaker mounting holes. There are ready-made spacers you can buy for this purpose but the make and model escapes me at the moment. If you search the Audio & Video forum you'll find a number of threads on this.
#83
make sure your spacers are not too wide(forgot exactly what size) but on my '04 i bought spacers that were 1/2 too wide and i had a hard time putting the door panel back on(bottom corner would not snap back on properly)..here's a couple links you can check out...hope it helps...
https://acurazine.com/forums/audio-video-electronics-navigation-22/step-step-making-spacers-door-speakers-286546/
http://www.chrishorne.com/gallery/TSXspeakers
#84
WOW! You guys have been a lot of help with all you suggestions, advice, and links
I think I'm ready to purchase those speakers now...but if I run into any problems along the way, I'll know where to go
#85
I've left this thread open because its an old thread with good info. If I close it then it'll drop off the horizon of new posts.
#86
Originally Posted by CJams
Very satisfied witht he Infinity's. I wanted Alpines, but was trying to stay right around $100 per set of speakers and the $100 alpines sounded like ass compared the Infinity's. They sounded the closest to Focals for the price. I don't plan on changing them til they blow.
#88
Originally Posted by nivla
Putting Polk db650's in the wife's TSX doors this week, the Alpine S type 6X9' s next week. For a stock system the TSX is very good but being a audiophile I couldn't standby and leave it stock . I'll post the sound eval later.
#89
I went to Best Buy to check Infinity speakers and they sounds nice and clear. It is on sale until Oct 1st. It save you about $110 dollar. I am considering to buy Infinity 6012I for front/rear and 9612I for rear deck or Infinity REF6010CS component speakers for front, 6012I in rear and 9612I for rear deck. What do you guys think? Hey Cjams, any suggestion? If I decide to buy it then I will install it myself at home instead of installation at Best Buy.
Check website: http://www.bestbuy.com/site/olspage....ry&id=cat03079
#90
Originally Posted by sonnyg80
drigo, you mentioned awhile back u got ur door spacers for circuit city correct?
#91
styling on you
1 Post
http://www.millionbuy.com/inf6010cs.html
Car domain at $160. http://www.cardomain.com/item/INFREF6010CS
#92
Originally Posted by SeCsTaC
Best Buy is a rip off. Those component speakers can be had for $125 instead of the $200 best buy is charging for them.
#93
I also checked on www.onlinecarstereo.com, they have good price for Infinity, component speakers cost at $129 dollar.
Check it out: http://www.onlinecarstereo.com/CarAu...roductID=15348
#96
#97
Originally Posted by jlukja
You really should go to Audio & Video in Off Topic
#98
Originally Posted by Joeys'TSX
Can you not move the threads to another forum? I'm a mod on another site and we just move them so you don't lose all the info gained.
#101
Hey do you think Infinity Kappa series are better quality than Alpine? I just wonder, I plan to get a upgrade speakers for my TSX, Infinity or Infinity Kappa or Alpine S. Any suggestion?
My setup is like this:
Front
AVI (Direct XL) 6.5" Components
Middle
Rockford Fosgate 6.5"
Rear
Alpine TypeS 6x9
Trunk
Two Phoenix Gold Octane 12" Subs
Phoenix Gold Octane Mono Amp
If I were to do again, I'll go with all Infinity Kappa series and two JL W6 12" or one W7 12"
#102
Originally Posted by PJS
I'm curious - first person to mention Focal in this thread, and it's in a negative way.
What exactly about the Focals didn't you get on with?
Was this in the same set-up/vehicle as the Infinity ones, or two totally different set-ups/vehicles?
I've been contemplating doing the speaker upgrade - plus iPod integration - and Focal were the ones I was going to use.
#103
#105
Originally Posted by minkl81
I bet you'll like Kappa series more. You should try them too before buying it.
#107
Hey I already ordered and installed the Infinity speakers into my TSX today and I love it. I am happy with it. Infinity sounds nice and loud. I am considering to buy 4 channel amps for 6.5 only or 4 and 6 channel for 6.5 and 6x9, but $$$$. Thanks to Cjams.
#109
References series, yeah. I have been considering to buy Infinity 1011t but not sure if it is worth or not to purchase it. Because I am deaf guy who can hear the music pretty well and feel the sounds and bass. That's why I am not sure if I should get Infinity tweeter or not.
#110
Guinea Pig
#111
Glad it helped. I still don't have any plans on upgrading the Infinity's. They sound great after more than a year. Although I will most likely remove the 6x9's and replace them with 8" speakers. I think I have it figured out. I just gotta find the right 8s. before that project goes forward.
#112
Guinea Pig
^^^ I plan on doing a little bit of modding to the rear dash before the install. there's lots of stuff back there that needs to be shut up tight. How did they mount the 8s? Any pics?
#114
there was no way i was going to keep it they way they had it sense it was just rattles. so i got two 12 inch infinity subs (yes i no that is a big diffrence lol) also got some 6012si for front doors and this is powerd by a 1000watt rockford amp.
and as of now there are no speakers in the back shelf
#116
rod and gomez - where'd you guys get the spacers for the infiniti's?
#117
NO one mentions frequency range here. When I look to replace speakers that do the bass work, I look for the lowest, even though that may not mean the bass is tight, or they sound the best. I played in a band in the 60's. Bass is supposed to be tight not like an elephant passing gas which is what some rap seems to sound like today. Music overloaded to one end (bottom) is not balanced. They make equalizers so you can boost bass and treble but also back off so one can hear the rest of the music. As to self installation, My '87 Integra was soooo easy. The door grills came right off and the screws holding them on were easy to get at and my Infinity 6 1/2 Kappas slid right in. My '96 GS-R had paper conel Pioneer speakers in it - I went with Boston Acoustics. Rear shelf speakers should never be paper conesl - sun rots them eventually.
#118
So what you're saying is, by upgrading the stock speakers to the Inifinity ones that I'm considering, I will definately experience clearer and better quality sound but will experience a small drop in sound volume.
In order to negate this problem, I would need to buy an amp, probably an Infinity amp to match my setup. So, this amp would deliver more power to the upgraded speakers so that I wouldn't experience this drop in volume and experience a better overall sound.
So, when I do decide to purchase an amp in the future, what kind/type should I get? 2-channel, 4-channel, 6-channel?...I have no idea which to get...also have no idea about the appropriate amp wattage.
Thanks for eveyone's help and advice...as you can tell, I'm very unfamiliar with car audio but doing my best to understand
#119
2 quick questions - can I/we get a quick recap on what ohm rating replacement speakers should be to minimise volume loss, as well as sensitivity rating? Sticking to the factory installed unit and no additional amps for now.
Also, has what's opinion on the Dynaudio kit/components these days?
Thanks guys
Thanks guys
#120
I'm pretty sure the factory speakers are all rated at 4 Ohms. Sensitivity isn't listed anywhere I can find, but since they're made by Pioneer, who usually has efficient speakers, I'd take a guess at ~92 dB.
