Last options question: Foglights?
4th Gear
I think I've posted a question about every option I'm considering on this forum except one: Are the foglights worth it? I'm somewhat surprised that they're not standard, but I seem to recall seeing some talk on this forum about them being suceptible to breakage due to their low position.
Does anyone have experience with them, pro or con?
Old fart
I like'em... They work great for me on rural roads at night.
I got fog light material on mine...but they did yellow on me once cause I left them on while I was taking pictures.
Old fart
Originally Posted by cruzingsilver
Fog lights are nice and good at night on long dark highway. Not absolutely necessary though.
TSX'R'US where did you get the fog ligh protector???
Not an Ashtray
Is there a particular reason the tsx fogs break? Are they glass lenses? I've had low fogs on all my cars for as long as I can remember without a problem.
TechLedr
They are a plastic, that does seam a little thin.
Check out this thread, where a wire mesh protector is used. I am in the process of making this mod, since I had the passenger side "rocked".
https://acurazine.com/forums/showthread.php?t=14669
ABP TSX
I added the OEM fog light kit myself after the purchase of the TSX. After 13 months, I noticed that the drivers side fog is severely cracked. I guess I will be replacing a rock damaged lens as well.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
This thread went into the effectiveness of these things at some depth. If you want a fashion statement, they're cute, but .... they are subject to damage from low rocks, they can't be used independent of the headlamps, which reduces their efficiency in true fog or ground blizzard conditions, and they don't do much when you do have the lows on. True fog lamps are designed to light the road surface while moving at VERY SLOW speeds in very foggy conditions, they are not designed to illuminate the road so you can crank back up to 80.......................... This thread deals with the topic pretty exhaustively, and there are some members who are installing their own fogs on an independent switch.
https://acurazine.com/forums/showthr...ght=fog+lights
I've had fog lights on a couple of cars, and the lenses broke, cracked and shattered due to low-road gravel and rock kickup. Replacing a fog lamp on my old Mazda Millenia ran about $500/lamp, n/incl labor..................... not worth it in my opinion. Spend the money on something else.........
Jewdacris!!
I actually bought some aftermarket PIAA foggies and after about 2 months i notice on of mine had cracked as well. So its not just the stock lenses that have this issue.
I have fogs on 3 of our cars; on one car I've replaced zero fog lights, zero headlights and zero windshields in 10 years, on another car, 2 fog lights, 4 headlights and 3 windshields in 7 years, and I'm still waiting for the first one to break on the TSX. Which it will, of course.
The complete TSX kits, BTW, go for about $280 from one of the Honda parts discounters, individual replacement lights would be less. The stoneshields are an idea, I've not purchased them because I use the fog lights a lot, they heat up and I've heard stories of the lenses cracking from heat buildup alone behind the plastic shield.
Originally Posted by gsclifton
I added the OEM fog light kit myself after the purchase of the TSX. After 13 months, I noticed that the drivers side fog is severely cracked. I guess I will be replacing a rock damaged lens as well. ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally Posted by darth62
In my opinion: yes. But, lets see what Acura has to say (I just wrote them about this issue).
quanaman
01-09-2023 07:33 PM
rboller
09-23-2015 02:49 PM
