Injen CAI instructions request
Rarrrrrrrr!!!!!!
If anyone knows a site that contains the instruction on how to install the injen intake for the tsx, or anyone with the instruction that can post it on this site. Please tell me.
Thanks in advance
Thanks in advance
Registered AssHat
Re: Injen CAI instructions request
Thanks in advance
Thanks in advance
Registered AssHat
Originally posted by virus7
wow thanks Lung Fu Mo Shi!
Now if you wouldnt mind wiring $200 into my bank account I can buy the CAI and start the install.
Registered AssHat
damn that looks very complicated.....Do you have to remove the bumper?
It's not complicated if you go step by step. It would probably take you 2 hours start to finish if you went real slow and careful.
I basically:
1) Took off bumper.
2) Removed resonator
3) Removed piping
4) Removed airbox
5) disconnected all hoses to stock airbox/hose
6) Removed unnecessary ones
7) Rerouted thottle body coolant line
8) Installed CAI mounts
9) Installed CAI tubing and adjusted
10) Attached vacuum hose (and others)
11) Attached filter
12) Replaced bumper
See...12-step program. ;P
My advice, do it on Saturday with no commitments all day. Don't rush it.
The hardest parts are:
1) Not dropping the bumper
2) Moving all those hoses...some of them were hard to get off.
Registered AssHat
So what kind of tools do you need for this?
1) Socket wrench
2) Old thin flathead screwdriver covered in electrical tape (for clip removal)
3) Philips no. 2 screwdriver
4) Needle-nose pliers (to help with the stock hose clamps)
5) Flashlight
Rarrrrrrrr!!!!!!
Again, thanks so much for your help.
By the way, did you install the CAI all by yourself? or did you have some1 else helping you out
Registered AssHat
Registered AssHat
ONE LAST QUESTION!!!
will this affect my TSX's warranty?
However, if for some reason your engine dies and has excessive amounts of dirt inside, the first thing Acura will do it blame your non-stock setup. Otherwise you should be fine.
Registered AssHat
ops almost forgot. Are there any differences between the polished intake and the black intake?
