important question! do i need special tools
im changing the clutch coil on my ac this weekend, it went bad couple weekends ago my question is what tools will i need to take the clutch off and the pulley off ? some people say i need a special clutch took and a pulley puller others say one nut and two snap rings hold it together so snap ring puller and a pulley puller at the most! so has anyone ever done one and done it with it on the car?
I haven't done this job on TSX, but have on 94 Accord. The clutch plate is held in place w/ single 10mm socket size nut. You will need a special tool to restrain the clutch pulley or an air impact to drive the 10mm socket.You may be able to rent a restraint tool from auto parts store (AZ, ORiellys, etc).
You will also need snap ring pliers to remove C-clip holding clutch pulley.
I recollect someone doing this job recently. Try searching for post.
Do you have a shop manual? If not suggest getting one from automanualsource.com for $22. It does not describe compressor clutch work w/ compressor connected to AC system, but does describe compressor removal and necessary steps to access compressor.
good luck
good luck
09-17-2015 09:01 PM
