How many quarts for automatic transmission drain and fill?
I'm about to drain and fill my tranny a couple of times. Do I need 3 quarts or 4 quarts to completely replace the fluid once? I've read/searched and heard mixed opinions. Don't want to buy more than I actually need.
In a nut shell, THREE. Just to make certain, to maintain the correct level, which is midway, or a little above the two holes, when I drain my 2G TL, I use 3, 1/2 gallon, empty milk cartons. and measure the exact amount of fluid i removed. I fill the first jug, to the top, and the remainder of the used fluid, goes in the second. I than fill the third jug, with fresh fluid, to the exact same level, as shown in the second jug, of used fluid. I also have two separate dip sticks. One, which I painted the bottom 3", with flat black paint. and use it for checking the fluid level, only. Makes the dip stick, much easier to read. The reason I use this method, is because, once the transmission is OVER/UNDER filled, it's a pain, to get it right again! I also find that, the angle of the car, determines how much fluid comes out. Sometimes, I drain less than three quarts, sometimes more. I would buy the extra quart, just in case!
PeteThaPitbull
01-24-2013 11:19 AM
dred87
05-10-2011 10:29 AM
Miamicarfan
05-16-2009 07:36 PM
Un-Kut
01-05-2005 01:05 AM
