How long is it safe to listen to the radio w/ the engine off?
Not a Registered User
the other day i sat in my car for about 15 min. listening to a cd. the car was still in the garage and the engine was off. the music sounds much better in my car then in my house. i didn't stay in there too long so as not to drain the battery.
i plan on doing this again. i fear one day i'll get in the car and it won't start because i spent too much time listening to music with the engine off.
can someone explain to me how the battery/engine interdependence works? is it true that the battery is drained much faster when the engine is off? why is that? how does the battery recharge?
thanks
thanks
i want to ride my bicycle
check but this might help get you started....
http://www.misterfixit.com/alterntr.htm
depends on the volumn level.. the higher the volumn the more the drain.
i wouldn't leave the radio on without the car running more than 30mins.. it can go many hours if you have it pretty low though.
Have camera, will travel
thanks
thanks
It seems to me that the TSX's battery isn't a particularly strong one. It's kind of small and doesn't fire the car up that well even when it's fully charged. I had never had this draining problem with previous cars, including a 2000 Accord EX V6.
So take it for what it's worth. Somewhere between 1/2 an hour and four hours you may kill the battery. The stock battery ain't no Die Hard.
Originally Posted by waTSX
I can relate a little story. I spent one Saturday washing, claying, polishing then waxing my TSX. The whole process took a solid four hours, and I had the stereo playing the whole time with the car off, CD and tuner. When I tried to crank the car, it was deader than a doornail. And yes, I was jamming the tunes, with the volume probably around 29-30 so I could hear it with the doors closed.
you have to factor all that in.. that is why the battery will drain much quicker.. especially if you have Navi.
Originally Posted by Sebo
yeah, but did your Accord have 8 speakers, an amp, and a subwoofer?
Edit: now that I think about it, I did have a sub in that car, in a custom box in the trunk. Forgot about that.
when i was in college i stupidly used my nissan altima as a boom box at a campus event we were throwing for oh about 3 hours. with tthe volume up high.
needless to say i needed a jump after that.
i'm sure you could probabl ygo an hour or more though. i've sat with a friend or two in a car just randomly talkign with music on for that long, no problems.
Yeah. Alpine V12 amp 4x50w, Alpine head unit, stock speakers. No sub though. Sounded pretty damn good.
Originally Posted by hellspare
What's the downside of having your engine on listening to music, but not moving? If there is none, then why don't you just do that.
Get a good battery. Interstate for the win!
In my old car, it powered 4 sats + 12" sub with 2 amps for 7 years before it finally died, and probably only because i left the door ajar in the garage overnight.
And this included many sessions of playing music with the car off, anywhere from 5 - 45 minutes.
well actually if u leave ur engine on and dont move ... u dont waste alot of gas .. infact almost none ... so i would go with that option .. and i do when im sittin in my car and listenin to music ...
so the tsx's oem battery is weak-average. if the battery recharges when the engine is running, then my only concern should be whether the car is going to start up the next session. correct? if so then all i'm looking for in an answer is for about how long can i listen to music (moderate level) with the engine off without surpassing the point where the car can't be turned back on without a jumpstart.
unless, the battery's longevity and reliability are hurt when listening to the music with the engine off, regardless if it recharges back to full capacity afterwards.
I've heard that its not good for the battery if you discharge it then recharge it (deep cycling). Listening to the radio with the engine off once in a while is no problem but if you run down the battery till it dies then recharge it then run it down again continuously will certainly shorten its life.
Just dial 1911
1 Post
I wouldnt trust our battery as far as I can throw it.
Exaggeration, yes. If I MUST listen to music in my car for a long period of time, that's what i would do.
I'm just saying.. I'd rather waste a teeny bit of gas than to have my car not start when I'm stuck in the middle of nowhere.
rockyboy
08-04-2024 10:35 AM
darksky
09-05-2015 03:11 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
