How far past the E
#41
6MT Snob
Originally Posted by bgillette
impossible...the tank is only 17.1gallons
That being said I wouldnt doubt that the fill tube could hold .6 gallons or more of gas.
#43
dude...there just is no way you can put in more than 17.1 gallons...
i'd be suprised if anyone can get more than 16.9 gallons in the car!!! You really would have to roll into the gas station on FUMES....and your fuel pump would HATE YOU!!!!!!!!!!
Why is it so hard to fill up right before or right when the light comes on? the gas is not going to get any cheaper (maybe a penny or 2)..so just go put some gas in it.....
Save your Car from all that crap in the bottom of the tank, and save your Fuel pump....
#45
Originally Posted by jlukja
... or the gas station where you fill up is ripping people off.
#46
Re-read the thread. That bottom of the tank stuff is a myth.
#51
donnie214
actually, I've seen a toyota 4 runner put in more gallons than the tank was supposed to hold... so I really wouldn't be surprized if the gallons ratings on fuel tanks are sometimes conservative...
as far as how much the tank really holds, well, I guess no one will really find out till one of us runs out of gas! of course, if it really holds 17.1 gallons, I'd have no problem putting in 15 to 16 gallons at every fill-up... the part that scares me is "what if" the tank only holds 17.1 gallons if you "top it off"... I've read in forums that an extra gallon can be squeezed in to the TSX if you repeatedly try to top off the tank when you fill up... So that would mean that every time I go to fill up and 15 gallons go in (without doing the top-off thing---i never do) that I only had about a gallon left. which is getting kinda scary to me.
but honestly, I wouldn't be surprized if the tank will take more than 17.1 if it was run dry. My past vehicle, a ford ranger, had a 20 gallon tank that I pumped 19.75 gallons into one time when "I was waiting for the next station" on an interstate that ended up being about another 20 miles away. I guess I'll never really know how much was left.
I guess the whole curiosity of "how much is left" is really just an issue of knowing. I mean, knowing is a heck of a lot more comfortable. If the light goes on and I know I can still go another 150 miles, well, that's pretty easing on my mind. But if I'm thinking, well, "I don't know if I'm going to run out of gas," hell, that's stressful. I think that's why most of us are really curious about the capacity thing.
Just for the record: the most I've pumped in one fill up was around 15 gallons. I think it's pretty close to the "E" at this level. My fuel light comes on at almost exactly the time when I can put 13 gallons in (maybe just a little less).
#52
the fathest i've gone past the "e" bar is a little before 7 o'clock. i filled up the tank a while ago with about 16 gallons worth. i assumed i had at least 20-30 miles worth of gas left. it seems the light comes on with about 4 gallons left, since i filled it up shortly thereafter and racked up a little less than 14 gallons at the pump.
#53
quite a coinsedence of a thread. my empty light came on 2 days ago. i filled up today, ahah
done it a few times. i filled up 58.3 L. got 469 Km out of the tank, more than normal, so thats cool.
the last time i ran it down so far it drained my battery trying to start (crappy battery/couldnt get fuel down the line). it worked out tho
#54
to be perfectly honest i dont pay any attention to the amount of gas i put in or how much it costs. i dont even select a particular gas station.
when the light comes on i pull into the gas station that is the easiest and or on the right side of the street and find a pay at the pump.
on a side note if they dont have pay at the pump i dont stop there.
i select 91 octaine and with the motor running let her fill up till its done.
when it asks me if i want a receipt i select no and no to the carwash question.
put the cap back on and go about my business.
i couldnt even tell you how much i put in or how much it cost because i really dont care.
i am glad it gets good gas milege but to be perfectly honest who really cares? i dont drive any certain way to save gas or anything like that.
i dont shop for gas prices. it costs what it costs and i let it fill till its done and i usually fill at 1/4 tank when on the highway travelling because eho knows how far the next gas station is? why take a chance?
#56
i check the numbers for a peice of mind, the values really dont make an impact on my life. i can say that my car gets to taste a little more gas than most of the other tsx's due to the milage difference tho
#59
And if you have Navi, the trip computer will tell you what your range is left before you run out.
Even that is conservative though.
If you go into the debug screens, it will tell you how much gas it thinks you actually have and how many true miles you can still go.
#60
I usually fill up when the light comes on, but last week I had to go close to empty.
Needle was in the E.
At the time of fillup:
Trip computer said I had a range of 24 miles left.
Navi debug said my range was 44 miles, with 1.1 gallons in the tank.
I put in 15.405 gallons to fill the tank. (I don't top off by the way.)
Was actually surprised it was a half gallon off.
#61
I'm surprised that no one mentions about moisture displacement in the tank when the fuel level is low, and can rust out the tank.
In theory, it sounds right that the fuel pump is cooled by submerging it in fuel. But in reality, the pump also gets cooled by the fuel flowing through it. How do you think in-line fuel pump gets cooled? It's mounted outside of the fuel tank.
#62
But the in-line pump is DESIGNED to be outside of the fuel tank. So it should have more features on it (fins, etc.) to improve heat transfer to the atmosphere. The tank fuel pump shouldn't need this (since you should have gas in the tank) and they don't put it on there to save manufacturing costs.
So the fuel flowing through the pump is "enough" to cool the in-line pump, but it may not be for the tank pump.
#65
This is a typical in-tank fuel pump. Note how the fuel flows and cools the inside.
Myth buster... Btw, there isn't much difference between the in-tank or in-line. Just the method of mounting.
Do you have a pic of an inline pump to compare?
#66
Top notch 6MT
#69
Tuxedo Cat
One thing to keep in mind is that the amount you can get into the tank, as well as the amount you'll be able to get OUT of the tank after it hits "E", is very dependent on the vehicle angle. If it's not parked absolutely level, there will be some variation as to how much you can get in, and if you're angled the wrong way after the guage hits "E", the engine may stop even though there's fuel in the tank.
Generally the gas gauge is a "worst case" scenario. Once you hit 'E', there are some situations in which there won't be enough fuel to reach the pump. These are probably sort of "oddball" situations, like a steep hill with a sideways grade on the road. In more normal environments you'll be able to keep going for a while, but nothing is guaranteed past "E".
In my old airplane, that had two tanks (one in each wing) I used to routinely run a tank dry. It is the best way of verifying fuel consumption, and when combined with a fuel flow meter it's also an excellent method of figuring out whether you have a leak. Would just let it run until the engine started to sputter a bit, then switch to the opposite tank and hardly lose a beat...
#70
Professional SLACKER
from experience..... Hondas always have about 3-4 gallons reserve once the needle hits E (lights on). On my TSX the E light is on whenever the tank only have 4 gallons left. Depending on how's your mpg on the tank..... the reserve will have anywhere from 65 - 100 miles. I tried it before.... my
#71
Originally Posted by ClutchPerformer
Can't see the pic...
Here's a pic of the inline fuel pump on my Toyota 4runner. It's a 2000.
It does not have any fins on it for cooling. IT's a pretty simple design. I think that it cools with the fuel running through it.
#72
Originally Posted by members78
i suggest someone actually run their car empty to a stop so we can find out how much exactly.
#73
#74
Here you go...
I can't find a diagram of the in-line internal. But you probably can tell from the outside. The oem style is very similar in design.
in-line pump:
in-tank pump:
in-line pump:
in-tank pump:
JTso
#75
But how much of that remaining fuel can you really use?
Originally Posted by VeniceBeachTSX
...In my old airplane, that had two tanks (one in each wing) I used to routinely run a tank dry. It is the best way of verifying fuel consumption, and when combined with a fuel flow meter it's also an excellent method of figuring out whether you have a leak. Would just let it run until the engine started to sputter a bit, then switch to the opposite tank and hardly lose a beat...
Anyway, to everyone else, something I have not seen mentioned here (and in the many other related threads :sigh: ), but that VeniceBeachTSX would appreciate, is that we care about useable fuel, not total fuel capacity. In airplane handbooks, you are given both the total capacity and the useable capacity. (The unuseable portion of fuel is considered part of the standard weight of the aircraft, and not used in fuel calculations, obviously.)
So yes, the TSX has a 17.1gal/64.7L tank, but how much of that is useable fuel? If you ran the car on a level surface until the engine quit, then took out the tank and measured the remaining fuel, how much is left? Does anybody know that number?
#76
Originally Posted by Dan Martin
That makes more sense. I couldn't see running out of fuel having anything to do with premature catalytic converter failure.
#77
How would it damage the cat converter? And if you run the tank dry till the engine stops, wouldn't you expect to not have any gas left in the tank? Do you think there is a hidden corner that holds gas for no reason?
#79
donnie214
Oh wait... actually I went to 15.811 gallons... and in case you were wondering, i don't "top off" (keep trying to put more after the pump shuts off the first time)
#80
Moderator Alumnus
This thread now has 3 lives!
Ok, based on my studies of gas and mileage, the farthest I've went with the gas light on was 254.7km. And I've found that the light and and gauge are very precise and reliable: they give out accurate measures.
Combine this with a complete fill (gassed up to the neck) at optimal MPG, one could travel for up to 1320km on a single fill.
Originally Posted by sauceman
I gotta admit that I've ran out of gas more than once in my life, and on the TSX, I can tell you, depending on the way you drive... in fact, if you really stretch it out thin, you can drive for around 250km with the gas light on. But please take my word for it, I don't want to be responsible for you running out of gas in the midst of heavy traffic trying to do just that.
I don't know exactly for how long you'll be able to drive with the needle at or past E
