How to change OEM dome courtesy/ambient
I just bought a the 1st gen TSX and don't have the service manual yet and I've search w/ no definitive answer. How do I change the LED ambient/courtesy dome? Is it a pain and should I just go to the dealer? Or can I just pop off the dome light assembly and replace the bulb? What size bulb is this? Just got this car and this little light went out already...
Or maybe I accidentally dimmed it? anyways to adjust this?
Thanks,
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
Thanks,
Thanks,
Thanks,
"1. Remove the two plastic pieces from the map lights.
2. Remove the two mounting screws
3. Disconnect the 3P connector from the housing
4. Disconnect the 10P connector from the ambient light
5. Carefully pry off the ambient light assembly from the map light housing while pressing in on the retaining tabs." Credit goes to Honda.
are you talking about dome lights bulbs... or are you talking about the blue LED spotlight?
The blue one is part of the hands free unit/homelink or something if I remember correctly.
btw, to remove the whole dome light ceiling piece, there are 4 bolts... the 2 inside the map light lenses like you mentioned above as well as 2 smaller black ones inside the sunglasses holder on the ceiling.
Those directions should have said to turn off the switch and make sure there is no power before sticking metal tools in there... kind of important here.
thanks guys. I'm talking about the small blue LED lights. So it's part of the whole assembly. So i have to replace the whole thing looks like. damn it! It's jus the blue LED light went out...
mugen_kid
11-13-2015 10:38 PM
nanos
11-12-2015 08:41 PM
