Hitch install on TSX
Hi,
Has anyone any experience having a hitch installed on the TSX? Apparently, acura doesn't make one.
I have a 2004 for which I would like to have a class I hitch installed. Any suggestions on where could I find one?
thanks,
blue
PS: my local Uhaul doesn't carry one either
thanks,
blue
yeah, thats what it looks like from reading the earlier threads. In that case hopefully i can get one custom made here. It will probably stilll be cheaper.
thanks,
blue
thanks,
blue
Engineer
Originally Posted by Dan Martin
Have you tried wal mart? They're the worlds biggest retailer of trailer hitches.
I don't see anything on their website, but i'll try contacting the store. I found a local welding shop that can make someting custom but that is going to be in excess of $500, plus wiring and all that. so not much different from teh euro option.
The good news is that, standard hitch for TSX will be available in a 3month time frame. Bad new offcourse is that I need something in a couple of weeks
send me a link to JDM??
Where am I getting this standarc hitch for the TSX in 3 months? I am in desparate need!!!!!
Originally Posted by elduderino
Just out of curiousity, what are you planning on towing with a TSX? A Weber grill?
I want to put a bike rack on it. My bike is under 30 pounds. So I don't think that it will be too much wieght. The bike rake itself might weight more than the bike.
I installed an accord hitch on my '05 tsx. I use it to tow a single jet ski (~550 lbs. plus trailer.) It handles the load with no problem. I have even towed a dual jet ski trailer a few miles in an emergency when another vehicle lost one circuit of their brake system. This was too much for the tsx. Anyhow, the installation involved removing the plastic covering under the trunk, drilling 2 holes under the spare, and making a bracket to adapt the third mounting point to the tow hook. The whole job took about 2 hours including the electrical.
Do you have any pics?? I'd like to do the same but don't want an ugly hitch hanging off the back of the car. I'm a cyclist and since parting with my SUV I have no good way to transport the bikes. Trunk racks ain't as stable and can scratch the finish. Roof racks are too noisy and messes up the TSX's nice lines. Did you do the install yourself?
Yes, it will be great if tjt889 can post some pics.
Originally Posted by waterrockets
Interesting, I called the 1-800 number back in June, and they had one for me, and could get it to my local UHaul. I still haven't seen one installed :-/
Originally Posted by BirchyBoy
Do you have your reciept with the UHaul part number in case the people we talk to need a nudge?
I checked out an Accord Coupe with a hitch and it shoudl work on a TSX
http://www.etrailer.com/productdetai...rfrom=2005&h=e
Of course, you can modify the hitch to work on it - but it's not a simple plug and play. Someone correct me if I'm wrong.
I was looking all over for hitch options, and finally ended up just getting a roof rack. I laid down some clear bra material to protect the roof at the rack mounting locations (purchased from RockBlocker). I bought some 6" wide bulk material and cut it to fit - worked pretty well with the Yakima Q towers.
That said, I'd buy a hitch right away if I knew which one to buy.
I don't think it will be a direct plug and play but close. I am probably going to build a custom hitch off this design since I need a 2" reciever for my bike rack.
If we do make one I'll take pics if it turns out good.
The Yakima Q-Towers are engineered for their purpose by the best rack manufacturer in the world, and the pads work with high friction. They really grip the roof, and that keeps them from moving even a little bit, which prevents any scratching.
Bra material is going to be a lot lower friction than the stock pads, and I think you may get some motion on the paint over time, which will scratch. Also, if the material doesn't seal to the paint like the pads do, you're likely to get some dirt under the edges. Once you get dirt in there, even tower flex will cause scratches without actually sliding.
I've been 4-wheeling (serious rock-crawling) in Moab with 4 mountian bikes on the rack. I also drove many inter-state trips with bikes on top at 80+ mph. Again, I had no scratching.
I'd hate to see you get some scratches, so check into it before you commit!
Bra material? Have you heard of someone doing this before? I wouldn't trust it myself. I had a Yakima roof rack on my 4Runner for 8 years. I just used the supplied pads, and pulled them off and cleaned the area every year when I waxed it. When I took the rack off to sell the 4Runner, you couldn't tell the pads had ever been on it (after a little cleaning). There was ZERO scratching - the paint was perfect.
Over spring break, I had a rental car and me and my buddies put a Yakima rack on it for the week to go snowboarding. Naturally, we didn't clean off the paint before we put the rack on, so there were some clear coat scratches when we took the rack off. So I was a little paranoid when I was planning on putting the rack on my car. (I frequent autopia.org, so I'm probably a little more of a sissy about the paint than most).
The clear bra material seems to stick very well. While installing the rack on my car (clamping it down), the rack mounts would move and the bra material stayed put. I'm pretty sure that the clear coat scratches I installed on the rental car were caused by putting the rack on and taking it off. So it seems like any scratches that I installed on my car would have and will go on the bra material.
Oh, also - the first time I put the rack on (on my car), I didn't clamp down the front bar tight enough, so it slid back a couple inches after driving on the highway. The clear bra material stayed in place while the rack moved back. So it appears that it's working like I had hoped.
If I see any damage to the paint, I'll report back later to warn others. But everything looks good so far. Thanks for the concern and advice.
FYI, there's a blue Civic Hybrid rental car in the LAX area with jihan3 installed clear coat scratches on the roof
So, what do we need to do to get more of these clear bras out on the market? Any chance we could get some binkinis made out of them?
TSX Trailer Hitch
I had a custom Class II hitch installed today to match up with a Thule 937XT Hitching Post Pro bike carrier on my 2005 TSX, Meteor Sivler Metallic, 5AT. The plastic piece under the trunk area had to be removed permanently to install the hitch. I think it is only for the aerodynamics for the underside of the car. The hitch is 1-1/4" and doesn't take away from the rear design of the car. I haven't figured out this picture attaching yet otherwise I would post some pictures of my installation. The company that did the work is in Kent, WA.
http://www.torklift.com
Please attach some pics!
To do so, upload your images at http://www.imageshack.us then copy the url they give you (there will be several, just get the "Direct link to image" version) at the bottom.
Then go back to this forum and this thread, click the "Quote" button on this post so you get the advanced post interface. Click the little yellow scenic icon at the top of the message box (tiny, yellow with mountains and a sun) and paste the imageshack url in the popup box.
For example:
Make sense?
Thanks so much, again!
[IMG][img=http://img464.imageshack.us/img464/4632/dscn05050vh.jpg][/IMG]
Ok, I did a quick adjustment to highlight the support bars for the hitch. I think it looks pretty good. It's pretty obvious that there's a hitch on there, but all things considered, I like it!
How much was it? Is it totally custom (like made just for you) or just custom in that it's available for all TSXs?
TSX Trailer Hitch
The hitch was custom made to attach under the TSX and match up to the Thule bike rack I have. The hitch was custom made and installed for $250. By the way what you see hanging down in the picture is the exhaust pipes, all the support for the hitch is hidden.
Looks good! Thanks for the pics + info.
I'd be interested in what kind of gas mileage you get with bikes hanging off the back. One time I averaged 20mpg over just under 300 miles - with 2 bikes on the roof, going about 80mph most of the time.
Over the summer, my friends and I averaged 18mpg over 2000 miles - in an RSX with a hitch mount bike rack + 3 bikes (ouch!).
Can't wait to drive
Bluepacific, that's a nice hitch and I would love to have a hitch rack to haul my bike. I cannot stand roof or trunk racks. Any contact information about the place you got the hitch from? and what type of hitch?
EDIT: nevermind..i re-read the post
Custom TSX Hitch
This company built the hitch to match the bike carrier that I had which was a Thule 937XT Hitching Post Pro, 1-1/4".
WHat makes this Thule rack so specific? Most hitch racks are very similar si I am curious what would keep a different rack from working. WHat is the name of the company and contact info. I'd be curious so see if they could explain the design and possibly replicate it for me if I were to weld on the support structures myself.
TSX Trailer Hitch
The Thule bike rack is not specific to the hitch I had installed. A standard hitch installed on the TSX would be hanging lower than the exhaust piping. This hitch was designed to match the Thule rack to accomplish two things: the hitch would be mounted up tight under the vehicle and would not take away from the sporty look of the TSX and the bike rack would not be hanging out a foot away from the back bumper but only 2 inches away. The company that installed this hitch for me is at the following web site:
www.torklift.com
www.torklift.com
You should hear how many Satellite Radio customers we get as well.
Originally Posted by RockBlocker
Actually, we get asked almost daily for this very reason. The pads that are supplied are going to move and cause friction while our product will adhere and not budge one bit. Scratching is not possible where the product is installed.
Your product may also work fine, but it can't be better than zero scratches or slipping.
Ummm, did you see the part where I said I drove hard with bikes on top for years with stock Yakima pads and never had a scratch?
I was more of less stating a fact that our product will not cause scratching of the paint with Yakima racks. Sorry if I offended you.
