The Hierarchy of High-Revving Engines: TSX's K24A2 in Good Standing
#41
Moderator Alumnus
Originally Posted by firedc5
aww crap i didnt see that thread, mostly because i dont surf this board, my best friend with a tsx is always talking about piston speeds so thats why i posted it.
That was an exact copy/paste.
What's more, the original thread is in this same forum, and it's 9 months old.
Of all the reposts I've seen, this has got to be the lamest one. And I'd add dishonest too. You could have just continued the discussion in that other thread.
#42
Moderator Alumnus
Originally Posted by TSXey
Anybody have insight into what we make of the data? Does it mean anything important? I haven't thought of high piston speed as necessarily good or bad.
Rod ratio is usually a more significant factor, I wonder if we looked at rod ratio for all those engines what we'd see.
If you add the piston speed to a difficult R/S ratio and other factors such as the engine's performance in fuel consumption, as well as emissions and even smoothness and ease of operation, you can soon see in the equation that the TSX engine is a jewel of an engine.
#44
Subie Tech
Originally Posted by gilboman
do some homework on the 2JZ pls. :o the supra engine is one of the most durable engines; strong too.
#45
Originally Posted by JeffTSX
Thank you. Someone knows their shit!!
#46
<-- gilboman
#47
maybe its the power difference, but maybe someone else has other anecdotes.
the tsx engine seems a lot smoother accelerating. feels like a giant electric golf cart motor or something.
when i had a g35 , the engine accelerating it felt a lot more like power came in lumps. i think the electricness of the tsx seems more refined thohgh probably less thrilling. its a great engine in its own right.
#48
Looking at this thread for the first time, we're just looking at average piston speed? The actual speed varies sinusoidally, where the max is when the piston is halfway through it's stroke (instantaneously at a crankshaft tangent).
For example, the S2000 would actually be at 7795 ft/min at it's mas speed vs. the 4965 ft/min average speed.
I guess it's all a wash anyway, because the speeds are all relatively the same between cars (max varies directly with average), so the list order wouldn't change.
Still, 7795 sounds so much faster than 4965
#49
Originally Posted by Power1Pete
inline 6 NOT = V-6
I rather like VWAG's solution with the VR6 engines (originally with a 15 degree V but now a mere 10.6 degree V).
You get most of the benefit of having an I6 (even a single cylinder head) while having a package that will fit were an I4 will.
#51
Moderator Alumnus
Still, it's pretty mind boggling when you think of it that the engine accelerates from 0ft/min to 7795 ft/min 19,000 times in an S2000 engine in a single minute.
#52
She said: it's GINORMOUS!
Originally Posted by Bananaairsoft
Give them a little more time guys! with the help of direct injection tech...very high rev and strong torq engines are well on their way!
#54
Originally Posted by sauceman
Indeed it does. Obviously though, I wasn't getting as scientific with this analysis, just posting out the average speed.
#55
Just out of curiosity does the V6 in the TL has any similarities to the NSX CB32?
As for I6 coming from Japan the only two engines that i've seen that are making big names for the japanese makers are the 2JZGTE and RB26DETT both of which are very old and low tech.
However, in the case of 2JZGTE it came with a very robust bottom end which is capable of handling 600 whp without any internal changes. In the case of RB26DETT is an even better engine only if it had come with a better oil pump/pan design. The oil pump/pan design is where it fails first.
#58
My Garage
Originally Posted by Maxboost
So why did Honda stop using the C32 then?
I could totally see a A-Spec TL with C32 tuned to 320 hp with SH-AWD running at limited production.
#59
Moderator Alumnus
They were also probably not worth the while adopting the latest variable timing technology, but that's mostly an uneducated guess.
#60
17781708
Anybody remember the I5's that honda used to make that were in legend's?
How did those perform? I'm just wondering if anyone knows anything about em?
If not, I guess that's why they met their demise
#62
#63
Moderator Alumnus
Oh, and they sounded like crap too: http://media.putfile.com/TSX-vs-Vigor-25
#64
1. Honda S2000:
Engine Code: F20C1
Bore/Stroke: 3.43" X 3.31"
Redline: 9000rpm
Piston Speed: 4965 Ft/min
2. Lamborghini Gallardo
Engine Code: N/A
Bore/Stroke: 3.25" X 3.65"
Redline: 8000rpm
Piston Speed: 4866.67 Ft/min
Good news guys, Hondata'ed TSX takes the title as the world's fastest piston speed from a production engine.
The S2000 is no longer #1 with it's longer stroke and slower rpm.
Hondata TSX is piston speed champion of the world 3.9 x 7600 / 6 = 4940 FT/min
People with a 04 TSX with hondata now have the fastest moving pistons from a production engine in the world!
Engine Code: F20C1
Redline: 9000rpm
Engine Code: N/A
Redline: 8000rpm
#65
Just dial 1911
1 Post
Originally Posted by project13TSX
1. Honda S2000:
Engine Code: F20C1
Redline: 9000rpm
Engine Code: N/A
Redline: 8000rpm
Engine Code: F20C1
Redline: 9000rpm
Engine Code: N/A
Redline: 8000rpm
#66
Drives a Sunfire
#67
Moderator Alumnus
Originally Posted by SoonToBeTSX'n
Interesting to see this talked about. Recently read this article, which would say you are incorrect... http://www.audiworld.com/features/tests/b7rs4.shtml The 06 Audi RS4 is taughted to do 25.7 m/s which is about 5011 ft/min (25.7*60*3.25), and that's stock. Course, what do you expect for a twin turbo v8 and 80k.
#68
Drives a Sunfire
The thread was written before the 2006 RS4 existed.
Besides that, I find it hard to believe that no Audis or MB were in the top 30 when you originally posted that, skip some brands maybe?
#69
Moderator Alumnus
Yes I know that, but the post I quoted was written...TODAY!
#70
Strange comment considering MB has never been known for high revving engines. At least not on this side of the pond. BMW, yes.
#71
Moderator Alumnus
#72
He's confusing engine power with the means to attain it.
Most likely.
Anyone know what the piston speed is on AMG's latest 6.2/6.3 L V8? That engine makes some very impressive naturally aspirated power.
#73
Most likely.
#76
im still waiting for honda's F1 3 liter V10 500+ HP in the next nsx
#77
Drives a Sunfire
#78
making 500 from 6.1 liter is easy... even americans can do it, honda will do it half its size with only 3 liters
Name one American car that makes 500HP from 6.1L?
Vette 6.0L makes 400 and of course the Z06 needs 7.0L (which is very impressive)
The SRT-8 6.1L makes 425. Again very impressive. It seems you need either huge disp or more than 8 cylinders to make 500 NA HP.
#79
Quick search shows it's 4469 ft/m. Let's make sure we're all on the same page here. I'll i'm saying is that the likelihood that there were NO Audis or MB in the top 30 seems impossible to me. I'm not saying I think they are all around better. And it's impossible to compare 06 models with the list you made based on what I would assume were 04 models. But if you look at the numbers on the current Audis, virtually every one of their engines is good enough to be on the list and the 04 S4 has the exact same engine as the 05 and 06. Clearly, I'm not leaning German or I'd be posting elsewhere, just stating a fact.
Not sure if your reffering to me but I agree with your comments. Just saying that MB in particular among the Germans aren't known for their high RPM engines or high piston speeds.
#80
Put into perspective, piston speed is mostly trivial. But it is a good indicator of how well an engine is put together.
also consider the reliability of the engine, and, you're looking at pretty good engineering...
