HID fog question
Old 02-15-2009, 07:09 PM
  #41
Team Hybrid
l7h8626's Avatar
Originally Posted by bc811
very nice and good job! those fogs look brighter than your low beam
they both are 35 watts i believe (unless the low beam is 55w, not sure), i think its because the foglights are not projected, so the lights flared out a lot and look brighter.
Old 06-16-2009, 09:50 PM
  #42
2003 TL-S A-SPEC
BIGTUFFGUY's Avatar
you do not have to remove the bumper. AT ALL. there is a screw under the fog light, unscrew it, stick your hand in front under, pop the light out... VOILA.
Once I figured this out, it was a 15 minute install.
A rock took out my drivers side fog this winter. i'm looking for a new one. The reflector is gone so you can see the light however it doesnt reflect onto the road nearly as well as the pass side.
Old 06-17-2009, 10:03 AM
  #43
Site Lurker, Rare poster
sortudo7's Avatar
^ To swap out the bulb itself, yes, that is all you have to do for the fogs. For a proper HID kit install into the fogs it is best to remove the bumper so you can properly place the ballasts and wiring, clean the areas etc.
Old 06-17-2009, 07:42 PM
  #44
E92
TommySalami's Avatar
It's also good because it's much easier to put the bulbs in without scratching them. I'll be ordering an HID kit soon because one of my bulbs has been out for a while now.
Old 06-17-2009, 07:59 PM
  #45
CGP Ebony
xenonhid's Avatar
How hot do the HID fogs get on the lens? Will they burn the rock blocker films like the halogen bulbs do?
  #46
tsxacurazine's Avatar
yesterday i just install my 8000k foglight HID turn out well and i mount it behind the bumper
Old 06-18-2009, 10:52 AM
  #47
sortudo7's Avatar
I've heard different things regarding this. I've heard some ppl have no issues with burning the films and then other's having theirs bubble or burn. Really doesn't seem to be a trend that can be tracked to see which type do what damage. Only thing I've figured is that those who have their films burn probably run their fogs all the time. I rarely run my fogs unless needed or I'm feeling like showing them off lol. My lenses get hot but not as hot when the regular bulbs were in there and it was on for the same amount of time and distance, I.E. coming home from work.
Old 06-18-2009, 06:49 PM
  #48
E92
Since the HID xenon bulbs produce less heat than halogen bulbs, they'll be better for films than using your stock bulbs.
Old 06-18-2009, 07:00 PM
  #49
E92
Originally Posted by wong05tsx
Pretty sure it's this one
http://cgi.ebay.com/ebaymotors/GENUI...Q5fAccessories
The ultraslim ballast design is nice, can pretty much slip it in anywhere.. comes with the dbl sided tape too. Install is simple and self explanatory
and I'm dropped on BC RSD's, with much to go before its all the way down.. but at that point i probably can't move. There's about 3" of tread left in the rear.
wo00o the pictures worked
Just bought a set of 3000K from this guy. Can't wait!
Where is the best place to get yellow rock blocker film to put over the lenses though?
Old 06-18-2009, 07:07 PM
  #50
9th Gear
tsxrhot1's Avatar
to save some $$ just get a luminics set for $31.50....
HID's without projectors are not worth $$...and with time the ballasts brake abd the bulbs become more expenses
If it is just for "looks"...get a LED bulb...they look like HID...but not much output...just looks
Old 06-18-2009, 07:09 PM
  #51
E92
I've gotten a couple sets of 3000K halogen bulbs. They broke after 6 months each. I want more light output this time, not for functionality but just looks, so I got HIDs
Old 06-18-2009, 11:01 PM
  #52
Tsx6363's Avatar
how do you aim your fogs
Old 06-19-2009, 01:51 AM
  #53
Need more room in
wong05tsx's Avatar
There's a phillips screw on the bottom of the bezel. Just turn it to aim it up/down. If you have HID's, i'd suggest aiming them very low.
Old 06-22-2009, 11:51 AM
  #54
Tsx6363's Avatar
what and where exactly is the bezel? lol
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
datadr
09-12-2015 09:12 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: HID fog question
