Help with tsx hood
Help with tsx hood
is there any difference between an 04 and an 05 hood? When i look online i see hoods for the tsx and it says 04-07 and then i see a couple that just say 04. Would that fit my 05 even though it says its for an 04?
Let me help you!
04/05 are the same. 06-08 are slightly different (ie: there's no chrome strip on the very end of it). As for sizes though, They should all fit. I think it's just that strip that's different. Since you have an 05 and you're looking at an 04, you should have no problem in either case
The other front-end difference between the 04/05 and the 06-08 is the grille/front bumper. They are interchangeable though (as I remember seeing pictures on a thread before), but you have to match the grille and front bumper together.
'03-'05 - no difference whatsoever.
As said above, pre-'06 and '06+ are replaceable but you need to replace grill as well.
Your current trim will/should fit the CF one if you so desired, unless the brand you opt for decided to make theirs like the '06 - homogenous rather than two-piece.
GWEEDOspeedo
01-15-2016 10:39 PM
