AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   1G TSX (2004-2008) (https://acurazine.com/forums/1g-tsx-2004-2008-124/)
-   -   Headlight Issues TSX 05 (https://acurazine.com/forums/1g-tsx-2004-2008-124/headlight-issues-tsx-05-a-935994/)
acuraST Sep 9, 2015 08:42 PM
Hello all,
Coming to this community for advice and assistance. Recently, I've been having issues with my headlights. When I switch on my headlights, I will have some moments where the driver side will come on and vice versa. Sometimes, neither will turn in. I usually have to flick on and off for a bit until it comes on and rarely is it both that will be on.
I recently changed my bulbs so I'm positive it doesn't need to be replaced. I also replaced one of the ballast on the passenger side. Still having the issue. I don't want to keep buying parts to do trial error because it's getting expensive.
Has anyone had this issue before?
01acls Sep 9, 2015 11:00 PM
1. Try swapping out the headlamp (L/R) relay one at a time with a known good relay from a fuse box in your car.
If the lights are still doing the same thing then your Igniters are probably bad.
2. Buy a Igniter and install it on the side that has the new ballast. It should work.
3. Now use the new igniter to test the other headlamp that has the old ballast. If it works then buy another igniter. If still not working then you have a bad ballast.
acuraST Sep 10, 2015 12:27 AM
Thanks for the input! I was really trying to avoid buying more parts to do trial and error but guess I have no choice! Any idea where I can find DIY for the fuse box?
01acls Sep 10, 2015 01:52 AM
No, not replacing any fuse box.
Just playing musical chairs with headlight relays #1 & #2 with another relay from your car. For this part you're not buying anything.
Below is an example from a TL. Duplicate the same on your tsx.
This is referencing Step #1 in Post #3 above.
https://cimg7.ibsrv.net/gimg/acurazi...900ef40565.jpg
https://cimg4.ibsrv.net/gimg/acurazi...e1be255544.png
Find your fuse/relay box under the hood. On it hopefully it will state where the Light 1 & Light 2 relay is. There should be a diagram on the cover similar to the pics.
Just find an relay that's an exact duplicate of the Light relay and swap them one side at a time and testing it one side at a time.
See pics below as examples.
https://cimg9.ibsrv.net/gimg/acurazi...91af49239e.jpg
https://cimg1.ibsrv.net/gimg/acurazi...04a951b81c.jpg
https://cimg2.ibsrv.net/gimg/acurazi...c5b3314d9a.png
01acls Sep 10, 2015 02:08 AM
To save money you might consider buying the ballast or igniter use from an U-Pull It or salvage yard... 50% off or more.
acuraST Sep 10, 2015 07:52 PM
Thank you sir! I'll give the fuse a shot first when weather cools down in SoCal. If that fails, I will purchase an igniter.
acuraST Sep 17, 2015 02:31 AM
After countless of days removing the bumper, I've finally figured out the issue. Turns out the igniter was causing all the issue. Extremely glad it was not the ballast.
© 2026 MH Sub I, LLC dba Internet Brands
